[Qgis-user] Can not install qgis-mapserver on CentOS 7
Richard Duivenvoorde rdmailings at duif.net
Fri Apr 14 04:36:39 PDT 2017
On 12-04-17 19:53, Julian Bogdani wrote:
> Am I missing anything? Should I install these dependencies manually? Or
> should I install some other package before?
> Any help would be much appreciated,
FYI: there is a rpm directory in the QGIS repo:
https://github.com/qgis/QGIS/tree/master/rpm
it contains some docs and spec files to be used to find dependencies.
I used the spec file some time ago to build QGIS-Desktop on CentOS 7:
http://zuidt.nl/blog/html/2015/10/12/build_qgis_master_with_oracle_provider_yourself_on_centos7.html
Note that master is currently to become 3.0 so you probably use 2.18 or
2.14 branch
Regards,
Richard
