[Qgis-user] Join multiple Linestrings to single Linestring
David J. Bakeman
dbakeman at comcast.net
Tue Apr 18 09:24:19 PDT 2017
On 04/18/2017 02:17 AM, Fuenfer-Koenigstein.Benjamin at swm.de wrote:
> Hi there,
> I want to merge multiple linestrings with same start/endpoint to a single linestring (all lines within one layer). As I use a PostGIS source with geometry type linestring, it is important that the new geometry is still linestring and not multilinestring type. "Merge selected features" tool and "JOIN" in QAD-Plugin both create multilinestrings. Has anyone an idea how to directly merge into linestring or how to change geometry type after merging? Thanks for your suggestions!
I'm not sure I completely understand what you want but you could run
multipart to singleparts from the Vector/Geometry Tools menu on the
multilinestring layer to generate a layer with just linestrings.
> Best regards
> Benjamin
> Qgis-user mailing list
