[Qgis-user] Layers not showing when .QGS file opened via shared drive
Árni Geirsson
arni at alta.is
Wed Apr 19 16:13:33 PDT 2017
I have had a problem where layers did not show up, only layer groups, that
I traced to the presence of a virtual layer. After removing that in a text
editor, the problem was solved.
Arni
Árni Geirsson
*Alta ehf* // +354 582 5000 // +354 897 9549
On 19 April 2017 at 21:51, Baker, Matthew <MATTHEW_BAKER at dpsk12.org> wrote:
> Hi all,
> (Sending this again without an attachment)
> I’m having an issue where a .QGS file created on a shared drive then
> opened from another computer doesn’t display any of the layers, though the
> information seems to be still in the QGS file.
> In the .QGS file linked below, when opened in notepad, I can see all the
> layer styling and connection information, but why doesn’t it show the
> layers when opened in QGIS?
> https://www.dropbox.com/s/udz8eb80u1i7lgp/Melissa_
> Compare_GeocodeV2%20-%20bug%20report.qgs?dl=0
> The map was created and opened using the same version of QGIS on both
> client machines.
> Can anyone see if there is something missing from the file that is
> preventing the layers from displaying?
> Thanks!
> -m
> *Matthew Baker *Denver Public Schools
> Department of Planning and Analysis
> matthew_baker at dpsk12.org
> 720-423-3419 / x33419
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170419/dd0bc34e/attachment.html>
