[Qgis-user] Number of vertices
Nyall Dawson
nyall.dawson at gmail.com
Sun Apr 23 22:06:45 PDT 2017
On 24 April 2017 at 11:52, Martin Bain <Martin.Bain at lismore.nsw.gov.au> wrote:
> Hi Anke,
> The asPolyline() function of a geometry returns a list of points. You can
> then simply get the length of the list:
> lyr=iface.activeLayer()
> sel=lyr.selectedFeatures()
> obj=sel[0].geometry()
> verts=obj.asPolyline()
> print verts
> [(526002,6.81305e+06), (526011,6.81309e+06), (526016,6.81311e+06)]
> print len(verts)
> 3
While this will work, it's quite slow as it requires copying all the
geometry's points into a new list. A faster approach is:
feature.geometry().geometry().nCoordinates()
In case you're wondering, the extra ".geometry()" gives you access to
the QgsAbstractGeometry interface containing all the low level methods
for working with geometry primitives.
Nyall
> Cheers,
> Martin.
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Anke
> zur Gölden
> Sent: Sunday, 23 April 2017 4:39 PM
> To: QGIS User List <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Number of vertices
> Good morning
> is there a way to get the number of vertices for a Polyline?
> I am looking for the python method to get if possible
> thx
> Anke
> This email is intended for the named recipient only. The information it
> contains may be confidential. If you are not the intended recipient you must
> not reproduce or distribute any part of this email, disclose its contents to
> any other party or take any action in reliance on it. If you have received
> this email in error, please contact the sender immediately and delete the
> message.
> Qgis-user mailing list
