[Qgis-user] QGIS Input Form for PostGIS
Andreas Neumann
a.neumann at carto.net
Fri Aug 4 00:39:24 PDT 2017
Hi Jakob,
I don't think there is much background information or documentation
available on relations.
The obvious questions to you are:
- What means "big" (how many records are you dealing with)?
- I know this sounds silly - but are your tables properly indexed (you
don't have to index primary keys, but other columns that are used in
relations need an index)
- What exact QGIS version are you using? 2.18.x - in the about dialogue
you can find this, including the exact github version string
- if we can't help you further, it may help to see your create table
statements (including all indexes)
Andreas
On 03.08.2017 11:47, Jakob Miksch wrote:
> Hello,
> I have a (rather big) Postgres/PostGIS database that basically looks
> like this: https://ibb.co/bK7PKv
> I want to use QGIS for editing and inserting data.
> I already found these ressources:
> https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/vector_properties.html#fields-properties
> https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/attribute_table.html#creating-one-or-many-to-many-relations
> https://docs.qgis.org/2.18/en/docs/training_manual/create_vector_data/forms.html
> I tried it: I created the relations and built custom forms.
> However, when I want to insert or edit something. QGIS becomes really
> slow and crashes finally. But before I describe the problems in more
> detail I want to read more about it. I find the documentation (linked
> above) a bit too little.
> So, my question:
> Is there any documentation I have missed?
> Is there any book (chapter) you can recommend?
> Do you know of any example where QGIS is used for entering data into
> many related tables in Postgres/PostGIS at once?
> I am thankful for any hint or resource.
> Jakob
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170804/f784ed77/attachment.html>
