[Qgis-user] ogr2ogr - how to use -s_srs, -t_srs and -a_srs
Andre Joost
andre+joost at nurfuerspam.de
Sat Aug 5 22:42:33 PDT 2017
Am 06.08.2017 um 02:22 schrieb Erik Josefsson:
> Hello,
> I have a handful of zip archives containing original shapefiles with
> different coordinate reference systems (e.g. SGER:3008 and SGER:3021).
> I want to extract and convert them all to SGER:3006 and thought that
> ogr2ogr would do the job, but I don't find intelligible instructions on
> how to use the srs-parameters: -s_srs, -t_srs and -a_srs.
You can either use -s_srs and -t_srs to reproject from one CRS to
another, or use -a_srs to assign a CRS if the source data has no CRS
information (like CSV), or has a wrong CRS (it is misplaced compared to
other data).
If the source data has a .prj file, the CRS information is stored inside
that. But beware that EPSG codes and datum shifts (+towgs84) are not
stored in .prj files. GDAL will try to auto-guess the EPSG code,but
sometimes fails. In that case, no datum shift will be applied. From your
example, EPSG:3021 must have a datum shift to WGS84, while the others
are based on ellipsoids with no shift to the WGS84 definition. So it is
safe to use -s_srs EPSG:3021 (together with -t_srs) for that data.
> Do I have to know the coordinate reference system of each original shape
> file to use ogr2ogr successfully? If so, how do I retrieve that information?
ogrinfo will report the CRS of every vector file supported by GDAL.
> Or should I just override the original coordinate reference system like
> this?
> ogr2ogr -f 'ESRI Shapefile' -s_srs EPSG:3006 -t_srs EPSG:3006 -a_srs
> EPSG:3006 A.shp B.shp
That will be wrong in most cases.
HTH,
André Joost
