[Qgis-user] background transparency
    Alexandre Neto
    senhor.neto at gmail.com
    Mon Aug 14 08:31:16 PDT 2017
There are so many reasons for updating QGIS from 2.6:
https://www.qgis.org/en/site/forusers/visualchangelogs.html
Richard McDonnell <richard.mcdonnell at opw.ie> escreveu no dia segunda,
14/08/2017 às 15:16:
> Brett,
> Apologies, ive just realised your version of QGIS may not have the
> processing toolbox.
> You may also do this by going to *RASTER*, *Conversion *and selecting*
> Translate *Its the very same tool just a different interface
> Regards,
> Richard
> On 14/08/2017 15:04, Richard McDonnell wrote:
> Hi Brett
> You can indeed, just use the Processing toolbox, just type Translate into
> the search box and select the Translate Tool under GDAL.
> The values you specified as transparent, can be specified under the Nodata
> Value
> You can also do this as part of a batch if you have a number of files, you
> wish to do this for.
> Hope this helps,
> Richard.
> On 14/08/2017 14:07, Brett Adams wrote:
> Hi Folks,
> I have a geotiff that contains a black ground in areas where there is no
> data.  The black background is made transparent within QGIS via “Layer
> Properties – Transparency”
> Can I export a new Geotiff with the black background removed?
> I’m running 2.6.1 On Windows-7.    Yes, I know it’s an old version but
> I’ve had no reason to update.  So far…
> Thanks
> *Brett  Adams*
> *Spinifex-GPX*
> *0438 861 974*
> Qgis-user mailing listQgis-user at lists.osgeo.org
> *Richard McDonnell*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> *Richard McDonnell*
> TEL: 01 6476543
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170814/ddb3fe31/attachment.html>
