[Qgis-user] Strike and dip symbology and labels
Lester Anderson
arctica1963 at gmail.com
Tue Aug 15 08:27:54 PDT 2017
Just added an example of what I mean. Basically it is making the dip
label follow the short tick; at the moment one has to manually adjust
the label position.
On 15 August 2017 at 15:32, Karl Magnus Jönsson
<Karl-Magnus.Jonsson at kristianstad.se> wrote:
> Hi!
> I can't visualize, in my head, what you are trying to achieve and what's going wrong. Can you supply a simple sketch?
> Karl-Magnus Jönsson
> -----Ursprungligt meddelande-----
> Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Lester Anderson
> Skickat: den 15 augusti 2017 15:06
> Till: qgis-user at lists.osgeo.org
> Ämne: [Qgis-user] Strike and dip symbology and labels
> Hello,
> I have strike and dip structural geology data and would like to plot the symbols with correctly positioned labels for the dip marker. The strike angle can be used for the rotation in a clockwise direction, but labelling the dip vector of the symbol is very hit and miss.
> A typical data file would be:
> Longitude, Latitude, Strike (clockwise from 0 degrees), dip direction (orthogonal to strike).
> Is there an easy method to deal with this? I can manually position the labels with offsets, but for a lot of data this would be a time consuming task!
> Thanks
> Lester
> QGIS version 2.18.11
> Qgis-user mailing list
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170815/c0538b17/attachment.jpe>
