[Qgis-user] AREA ATTRIBUTE FOR VECTOR LAYER
    Christine
    geo.guide at web.de
    Thu Aug 17 13:41:02 PDT 2017
Hi Ricardo,
if you want to get a density of school points in each polygon, you may
calculate this in the field calculator.
Assure, you are working in a projected coordinate sytem. Open attribute
table and choose 'open field calculator'. With the field calculator dialog
open, give a name to a new attribute for school density, choose an
appropriate output field type (probably decimal number, real), output field
length and precision and use an expression pattern like
 <name of attribute of points count>  / $area
You get the correct syntax of your  <name of attribute of points count>
doubleclicking on the field's name under 'fields and values'. Be aware that
$area will have the dimension of the squared coordinate reference system's
measure unit (feet or meters). If you want a density based e.g. on km you
have to devide your area accordingly.
Regards, Christine
View this message in context: http://osgeo-org.1560.x6.nabble.com/AREA-ATTRIBUTE-FOR-VECTOR-LAYER-tp5331699p5331704.html
Sent from the QGIS - User mailing list archive at Nabble.com.
