[Qgis-user] Maximum wfs layers in qgis?
Jorge Gustavo Rocha jgr at di.uminho.pt
Mon Aug 21 16:05:40 PDT 2017
Hi Dan,
I can reproduce the error. Please fill a new bug in https://issues.qgis.org
There was a related issue (#15602) that is already closed. I think the
problem you are facing is different.
Meanwhile you can download the data in a script to a temporary folder,
while the wfs provider is fixed.
Something like curl is enough to download the data:
curl
"https://maps-public.geo.nyu.edu/geoserver/sdr/wfs?service=WFS&version=2.0.0&request=GetFeature&typenames=sdr:nyu_2451_34490"
-o nyu_2451_34490.gml
I hope it helps.
Regards,
J. Gustavo
On 21-08-2017 19:55, Dan Meerschaert wrote:
> When I look in the cache/wfsprovider folder, there's another folder with
> almost three times the layer number in other files: wfs_cache_XX.sqlite,
> -shm, and -wal.
> I had to track down a public wfs with a small enough sample set to be
> repeatable. This Python code gives the error in 2.18.7 and a 2.99
> nightly I grabbed for testing:
> iface.addVectorLayer(' restrictToRequestBBOX=\'1\' srsname=\'EPSG:4326\'
> typename=\'sdr:nyu_2451_34490\'
> url=\'https://maps-public.geo.nyu.edu/geoserver/sdr/wfs\
> <https://maps-public.geo.nyu.edu/geoserver/sdr/wfs%5C>' version=\'auto\'
> table="" sql=',"example01","WFS")
> __
> table="" sql=',"example02","WFS")____
> table="" sql=',"example03","WFS")____
> table="" sql=',"example04","WFS")____
> table="" sql=',"example05","WFS")____
> table="" sql=',"example06","WFS")____
> table="" sql=',"example07","WFS")____
> table="" sql=',"example08","WFS")____
> table="" sql=',"example09","WFS")____
> table="" sql=',"example00","WFS")____
> table="" sql=',"example11","WFS")____
> table="" sql=',"example12","WFS")____
> table="" sql=',"example13","WFS")____
> table="" sql=',"example14","WFS")____
> table="" sql=',"example15","WFS")____
> table="" sql=',"example16","WFS")____
> table="" sql=',"example17","WFS")____
> table="" sql=',"example18","WFS")____
> table="" sql=',"example19","WFS")____
> table="" sql=',"example10","WFS")____
> table="" sql=',"example21","WFS")____
> table="" sql=',"example22","WFS")____
> table="" sql=',"example23","WFS")____
> table="" sql=',"example24","WFS")____
> table="" sql=',"example25","WFS")____
> table="" sql=',"example26","WFS")____
> table="" sql=',"example27","WFS")____
> table="" sql=',"example28","WFS")____
> table="" sql=',"example29","WFS")____
> table="" sql=',"example20","WFS")____
> table="" sql=',"example31","WFS")____
> table="" sql=',"example32","WFS")____
> table="" sql=',"example33","WFS")____
> table="" sql=',"example34","WFS")____
> table="" sql=',"example35","WFS")____
> table="" sql=',"example36","WFS")____
> table="" sql=',"example37","WFS")____
> table="" sql=',"example38","WFS")____
> table="" sql=',"example39","WFS")____
> table="" sql=',"example30","WFS")____
> On Aug 21, 2017 12:55 PM, "Jorge Gustavo Rocha" <jgr at di.uminho.pt
> <mailto:jgr at di.uminho.pt>> wrote:
>     Hi Dan,
>     QGIS uses a local SpatiaLite database to store the features on the
>     client side. The cache should be in your .qgis2/cache/wfsprovider
>     folder. Can you check the contents of the folder?
>     If your WFS is a public server, can your share the service URL and the
>     layer/layers to reproduce the problem?
>     Regards,
>     J. Gustavo
>     On 21-08-2017 16 <tel:21-08-2017%2016>:42, Dan Meerschaert wrote:
>     > I'm working on a plugin for QGIS 2.18.7 on Windows that (as a part of
>     > its other function) grabs many wfs layers at once.
>     > The problem is, after about 30-50 simultaneous connections, QGIS
>     throws
>     > up a "Cannot create temporary SpatiaLite cache" error in the WFS log
>     > panel and doesn't load all the data.
>     > I'm able to repeat this by picking any given wfs layer, and
>     duplicating
>     > it manually using iface.addVectorLayer (...) in the python console.
>     > Can anyone help me out?
>     > Respectfully,
>     > -Dan
>     > _______________________________________________
>     > Qgis-user mailing list
>     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     J. Gustavo
>     Jorge Gustavo Rocha
>     Departamento de Informática
>     Universidade do Minho
>     4710-057 Braga
>     Tel: +351 253604480 <tel:%2B351%20253604480>
>     Fax: +351 253604471 <tel:%2B351%20253604471>
>     Móvel: +351 910333888 <tel:%2B351%20910333888>
>     skype: nabocudnosor
J. Gustavo
Jorge Gustavo Rocha
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
skype: nabocudnosor
