[Qgis-user] Updating a field set with default global variable on edit
McDonaldR McDonaldR at angus.gov.uk
Tue Aug 22 06:36:48 PDT 2017
Thanks Karl-Magnus
We use triggers in the database already and they work perfectly but if we want to record the specific user creating and editing features then we'd have to create separate projects for each user.  At the moment the team of about 10 users all use a set of centrally stored project files - one for each different task.
I found this post on Stackexchange (https://gis.stackexchange.com/questions/217011/how-to-automatically-update-wfs-edits-with-a-user-id) where global variables are used to populate fields when features are added.  However, as Matthias notes in the comments this doesn't work on feature  "update".  If this were possible then it would meet all our needs.  Maybe something that could be funded?
Ross
From: Karl Magnus Jönsson [mailto:Karl-Magnus.Jonsson at kristianstad.se]
Sent: 22 August 2017 12:34
To: McDonaldR; qgis-user at lists.osgeo.org
Subject: SV: [Qgis-user] Updating a field set with default global variable on edit
Hi!
I've made the same things with triggers in the database. To avoid getting same username I've chosen not to save the username and password in the project. But then the user have to enter it every time the projects opens. If you can find a solution to your suggested approach it would be nice.
Karl-Magnus
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För McDonaldR
Skickat: den 22 augusti 2017 13:12
Till: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Ämne: [Qgis-user] Updating a field set with default global variable on edit
Hi List,
Anyone know how to update a field that has a global variable set as the default value when records are edited (geometry and/or attributes)?
We have a QGIS project with a PostGIS layer loaded and configured with look-ups and relations so the users can update all the relevant fields. There are also "created_by" and "updated_by" fields. These are updated by a trigger in the database with the "current_user" database variable. This works fine if you are the current user that added the layer to the project - the trigger works perfectly.
If you give the project to someone else and they create and edit features in the layer the fields are still updated with your name as you are the person who added the layer to the project. Not what we want.
QGIS has global variables and there are some new ones - user_account_name and user_full_name that can be set as default values for the fields. When a new feature is created the field is populated with the correct name. Which is what we want.
However, when we update an existing record we'd like the "updated_by" field to be updated with the current "user_account_name". Like a trigger in the database would do on update. Then we would have a better idea of the history of the feature.
Ross
Ross McDonald | GIS Data Coordinator | Angus Council, People, IT | Angus House, Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT | t: 01307 476419
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170822/f9a36458/attachment.html>
