[Qgis-user] Presets in Layers Panel
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Sat Dec 30 01:51:22 PST 2017
Hi Lene,
You need to add a new Style. Each style will be then attached to a preset.
In your layer tree, right-click on the layer you want to change the style,
Styles > Add
Then, go to properties and set the style you want. Once the style is done,
you can create the preset. Repeat the above for each preset/theme.
Hope that helps.
Regards
Saber
On 30 December 2017 at 08:54, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi Nyall,
> You can change the setting for a layer eg. Color and then make a preset.
> So if I have a layer and I want to present it in 3 different
> colors/classifications
> How would you then suggest I make 3 different presentations ?
> Kind regards
> Lene
> Lene Fischer
> -----Original Message-----
> From: Nyall Dawson [mailto:nyall.dawson at gmail.com]
> Sent: 29. december 2017 23:46
> To: Lene Fischer
> Cc: qgis-user
> Subject: Re: [Qgis-user] Presets in Layers Panel
> On 30 December 2017 at 08:07, Lene Fischer <lfi at ign.ku.dk> wrote:
> > Hi,
> > I´m trying to use the ‘Preset’ function in the Layers Panel.
> > But I can only add one preset and then ‘Add Preset’ is greyed out.
> > It might be me who use it wrong, but could I get someone to try it out
> before I file a ticket.
> Yep, you're using it wrong! :)
> Think of creating presets like a "snapshot" of the current configuration.
> The action is disabled if the current state already matches an existing
> preset. So you need to make some change to the configuration (e.g. toggling
> some layers), and then you'll be allowed to create another preset.
> Nyall
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171230/9419e322/attachment.html>
