[Qgis-user] sip-api-11.2 and qtbase-abi-5-5-1 prevent installing qgis 2.99 nightly on kde neon / ubuntu 16.04
Andre Joost andre+joost at nurfuerspam.de
Sat Dec 30 23:13:49 PST 2017
Am 31.12.2017 um 02:19 schrieb Jason Paul Joines:
>          I also have a newer version of python-sip, which is supposed to
> provide sip-api-11.2:
> # dpkg -l python-sip
> Desired=Unknown/Install/Remove/Purge/Hold
> Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
> |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
> ||/ Name                                               Version
> Architecture                   Description
> ii  python-sip 4.19.2+dfsg-1+16.04+xenial+bui
> amd64                          Python/C++ bindings generator runtime
> library
I guess the newer version spoils your installation. My Xenial
installation is build against python-sip 4.17 from the main ubuntu repo,
and works fine.
It might be that python-sip 4.19.2 includes a different version of
sip-api, which is of no use for you.
Try to downgrade python-sip, and libqt5core5a as well, which comes as
5.5.1 from the main repo for me.
If KDE Neon does not provide it, try to force the main ubuntu repo version.
HTH,
Andre Joost
