[Qgis-user] Selecting Objects from an ESRI file based geodatabase
Tyler Veinot tylerkveinot at gmail.com
Wed Feb 1 06:45:54 PST 2017
You could add the layers you need and use the convert to offline project
button to convert the layers to sqlite. I have done this to our file
geodatabases but it doesn't work for Z and ZM features, some field data
types will throw errors that may or may not halt the export. Then you might
be able to use some SQL filters in the database to limit or group certain
layers.
On Wed, Feb 1, 2017 at 9:30 AM, Lester Anderson <arctica1963 at gmail.com>
wrote:
> The only way I am aware of, is to load the .gdb file, select the
> layer(s) you want and then use the save-as option to save out as a
> shapefile.
> On 1 February 2017 at 12:22, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> > You can right click a layer and go to filter and enter an expression to
> > filter out unwanted objects. From there save as will save to a shapefile,
> > among other other formats, that will only be the items defined by the
> > filter. You can also use a select expression and in the save as dialog
> > select save only selected features
> > Does that help?.
> > On Wed, Feb 1, 2017 at 8:12 AM, Armin Konrad <armin.konrad at email.de>
> wrote:
> >> Hi,
> >> I have opend an ESRI .gdb database (directory) in an qgis project. The
> >> mayor .gdbtable-file has a size of about 3.5 GB and contains about
> 18.000
> >> objects (polygons). It is rather awkward to work with such a database
> to say
> >> the least since I need only 2 to 3 objects at a time.
> >> I wonder, is there a way to select certain objects by filtering and
> >> convert them selectively to a shape file or to copy them to a new
> database?
> >> Thanks you for suggestions.
> >> Armin
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170201/af1092be/attachment.html>
