[Qgis-user] Symbology export for Geopackage?
Andreas Neumann
a.neumann at carto.net
Sun Feb 5 12:24:55 PST 2017
Hi Morten,
The current way of saving styles in geopackage is through the Layer
properties dialogue --> "Style" tab.
If your data source is Geopackage it will offer to save the style in the
same geopackage. It is the same way as you would save a style in Postgis
or in SpatiaLite.
If you think there is a better way than the above (e.g. when saving a
layer also save the style), please open a feature request with a
detailed proposal, or even better try to find a developer who would
implement it for you.
Greetings,
Andreas
On 05.02.2017 19:50, magerlin wrote:
> The Geopackage seems like a nice format for exchanging data, symbology etc.
> in one file and I can manually from layer properties store the layer style
> in the Geopackage.
> But already when I choose "save as" in the layers panel to add my data to
> the geopackage I am presented with the possibility to export the symbology
> together with the data which would save me a lot of clicks (I have several
> projects with 20+ layers)
> But it has no function choosing that.
> Should it work or am I doing something wrong?
> And I do not understand the two alternative choises:
> * Feature Symbology
> * Symbol layer symbology
> Any experience on this subject?
> Regards Morten
> Currently using Qgis 2.18.3 (OSGeo4),
> Windows 7, 64bit
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Symbology-export-for-Geopackage-tp5306376.html
> Sent from the QGIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
