[Qgis-user] [Qgis-tr] Porblems with labeling Coordinate grid and the numbers-Change
Werner Macho
werner.macho at gmail.com
Tue Feb 7 02:54:19 PST 2017
Hi Stefan,
Thanks for your question, but the qgis-tr mailing list is mainly for
translation discussions.
I forward your mail to the correct mailing list for these kind of
questions (qgis-user).
Hope you are subscribed there.
>From fast reading your questions can all be solved by playing around
with the labeling options.
But I am sure you will get more detailed answers on the qgis-user mailing list.
regards
Werner
On Tue, Feb 7, 2017 at 10:49 AM, Reist Stefan
<Stefan.Reist at langenthal.ch> wrote:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/qgis/
> Hi,
> Im using QGIS 2.14 and i have the following 2 Problems: Both Problems are in the Print Compilation:
> - How i can the labeling Coordinate move, that this are not on the Coordinate Line, rather a little bit higher?
> - How i can change the Numbers on the side the map. Now it's beginns from top to bottom with the numbers 10 to 1. But now i will change this chronology from top to bottom and beginns with 1 to 10. Can someone help me?
> Thank you for the help!
> Steven
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
