[Qgis-user] Porblems with labeling Coordinate grid and the numbers-Change
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Tue Feb 7 04:40:49 PST 2017
Hi Stefan,
I can't answer to your questions, cause I have real difficulties
understanding your problems.
I just can advise you to switch your QGIS language to English under
"Settings/Options/Locale", so you are able to use the correct terminology
in English when posting questions and searching for answers.
It would always be good to have screen shots to be able to visualize the
problems, but as the mailing list has a limit of 100kb for attachments,
it's sometimes hard to do so.
A better resource for help on such things IMHO is stackexchange. E.g. for
your problems use
http://gis.stackexchange.com/search?q=qgis+composer+coordinates to get a
list of questions/answers that might cover your issues.
Cheers
Bernd
Am 07.02.2017, 11:57 Uhr, schrieb Reist Stefan
<Stefan.Reist at langenthal.ch>:
> Hi,
> Im using QGIS 2.14 and i have the following 2 Problems: Both Problems
> are in the Print Compilation:
> -          How i can the labeling Coordinate move, that this are not on
> the Coordinate Line, >rather a little bit higher?
> -          How i can change the Numbers on the side the map. Now it's
> beginns from top to bottom >with the numbers 10 to 1. But now i will
> change this chronology from top to bottom and beginns >with 1 to 10. Can
> someone help me?
> Thank you for the help!
> Steven
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170207/ab65a8ef/attachment.html>
