[Qgis-user] Data Defined operation
Saulteau Don sault.don at gmail.com
Tue Feb 7 20:34:10 PST 2017
It says it wants to see the colour value as a string.
So in your case, you can use a CASE THEN ELSE END statement to get there.
CASE WHEN "Type" = 'SL' THEN '255,0,0,100' END
There the numbers represent 'red,green,blue,alpha'
Alpha is the transparency value. 0 is completely transparent and 100 is not
transparent.
On Tue, Feb 7, 2017 at 9:08 PM, Springfield Harrison <stellargps at gmail.com>
wrote:
> Hello,
>     Attempting to use the Data Defined function (tool?).
>     The following configuration has no effect; it may be looking for a
> colour input.  This DD is to set the background colour on a label where
> Type = SL.
>     If I use this function on bold Text, it works but that requires no
> input, it just toggles.
>     Where am I supposed to enter the "Expected Input" colour
> specifications?
> Data defined override
> Active: yes  (ctrl|right-click toggles)
> Expected input:
> string [r,g,b,a] as int 0-255
> Valid input types:
> string
> Current definition (expression):
> "Type" = 'SL'
> Thanks very much . . . .
> Cheers . . . . . Springfield Harrison
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170207/8a914a5e/attachment.html>
