[Qgis-user] Simple methodology for user / data / map interactivity?
Bernhard Ströbl
bernhard.stroebl at jena.de
Fri Feb 24 00:16:56 PST 2017
Hi Graeme,
QGIS can do what you describe in your example out of the box.
Workflow:
0) copy layer
1) select polygon in layer
2) use the spatial query plugin
- select source from layer_copy
- Where the feature intersects
- reference features of layer (tick 1 selected polygon)
- apply
3) zoom to selection of layer_copy
If you work with PostGIS you can use the layer's filter to enter any SQL
thus restricting the features to those that fit into the filter rule.
Then zoom to the layer and you are done.
You can load the result of a query against a PostGIS DB as layer into
QGIS, too, by using DB manager.
For automation Processing's graphical modeler might be worth looking at.
Of course you can do most things with a plugin that you e.g. connect to
a layer action. I am always reluctant to write a plugin for workflows
that can be performed using QGIS' standard tools, though.
I know users like to klick on a dedicated button and then something is
run just the way they (think they) need it, however IMHO the smarter
approach is to train the users to do these tasks themselves with the
standard tools.
Bernhard
Am 23.02.2017 um 18:48 schrieb SEGGIE Graeme:
> I would like to use QGIS as a visual / interactive front to some PostGIS
> data and am not sure what the best route to doing so is. Happy to
> explore further myself, but wanted to get some input on what needs to be
> joined up to get started on building a little process.
> Basically, if I wanted to present a map of features and have a button
> (like the attribute information one) which a user would click then use
> to select features, I want this to run a SQL query which to get related
> features for example and highlight them on the map view, possibly pan to
> the extent of the newly selected feature set.
> Does this sound like a plugin – or would that be taking things too far?
> Would the best way for the dynamic layer to be setup, to be a view –
> empty except when populated by the query and styled to be dominant over
> the full set of features?
> As a simple example, say I had a district zone system of polygons and I
> wanted a user to be able to click on any polygon, and have all the
> neighbouring polygons highlighted, centred and fill the map view as
> fully as possible. What would be the best / simplest approach to this?
> Graeme
__________ Information from ESET Mail Security, version of virus signature database 14988 (20170224) __________
The message was checked by ESET Mail Security.
http://www.eset.com
