[Qgis-user] qgis 2.18.3 not installing on win 10
Andre Joost
andre+joost at nurfuerspam.de
Sun Feb 26 08:23:38 PST 2017
Am 25.02.2017 um 21:58 schrieb Michael.Dodd:
> Have been using qgis for years. Just uninstalled 2.14 and installed
> 2.18.3 but it refused to start saying that qgis_app.dll,
> qgis_core.dll and qgis_gui.dll are all missing.
> Infact they are not missing, they are all present. However it seems
> to be looking in the wrong place, think similar problem has occurred
> with one or two previous versions. I am NOT installing on c: drive
> as it has little space but instead installing on y: drive. This
> worked fine for version 2.14 and various other programs but with
> version 2.18.3 it does not work.
You could try the OSGEO4W installer. It lets you choose the root
directory where everything is installed to.
Or have a look at \QGIS 2.18\bin\qgis.bat and o4w_env.bat. The variable
OSGEO4W_ROOT might be set wrongly. You get it when you type set inside
the OSGEO4W Shell. Override the definition if necessary.
HTH
André Joost
