[Qgis-user] WMS via https - "SSL handshake failed"
Jorge Gustavo Rocha jgr at di.uminho.pt
Tue Jan 3 15:57:58 PST 2017
Hi John,
I've added your WMS service and it works without any problem. I've just
added the url and the connect works. The capabilities are displayed.
You can check the print screen [1] with your https WMS layer.
I'm using QGIS 2.18.2 on Ubuntu. Which OS are you using?
Regards,
Jorge Gustavo
[1] http://webgis.di.uminho.pt/~jgr/wms%20with%20https.png
Às 17:42 de 03-01-2017, John Cartwright escreveu:
> Thanks for your reply Luigi!  To be clear, the WMS service that I’m
> trying to connect to does not require a username/password but is only
> available via https.  The server (https://maps.ngdc.noaa.gov) has a
> valid CA certificate.  I tried adding a SSL Server Configuration
>  (preferences -> authentication -> Manage Certificates -> Server) and
> while the entry appears to be valid, I still get the SSL Handshake error
> when trying add a WMS layer.
> Any further ideas?  Here’s the actual URL I’m trying to add:
> https://maps.ngdc.noaa.gov/arcgis/services/gebco08_hillshade/MapServer/WMSServer?request=GetCapabilities&service=WMS
> Thanks again for your help!
> —john
>> On Jan 2, 2017, at 1:52 AM, Luigi Pirelli <luipir at gmail.com
>> <mailto:luipir at gmail.com>> wrote:
>> Hi John
>> SSL is managed storing credentials using the QGIS Authentication
>> Manager that store credentials in the same way as Firefox, in a master
>> pwd crypted store in your $home/.qgis2/qgis-auth.db.
>> You should managed credentials using Settings->options->authentication.
>> QGIS uses OpenSSL => and specifically can import different king of
>> credential method (using plugins => can be expanded). De default auth
>> method installed are listed in the documentation:
>> https://docs.qgis.org/2.14/en/docs/user_manual/auth_system/auth_overview.html
>> what is you auth method? can you explain the workflow you followed to
>> store and use your credentials?
>> regards
>> Luigi Pirelli
>> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
>> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>> * GitHub: https://github.com/luipir
>> * Mastering QGIS 2nd Edition:
>> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>> On 29 December 2016 at 22:38, John Cartwright
>> <john.c.cartwright at comcast.net> wrote:
>>> Hello All,
>>> I’m trying to use a WMS service over https and get the following
>>> error when trying to connect:
>>> Failed to download capabilities:
>>> Download of capabilities failed: SSL handshake failed
>>> The URL works fine in a browser though.  I’m guessing that QGIS and
>>> the server are not able to agree on a cipher suite.  Can anyone tell
>>> me what ciphers QGIS supports or any way to get more insight into the
>>> underlying problem?
>>> QGIS is version 2.18.2.
>>> Thanks!
>>> —john
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
