[Qgis-user] Symbolizing a discrete or a boolean raster
Stéphane Henriod
s at henriod.info
Mon Jan 9 08:25:24 PST 2017
Hi
unfortunately this is doing quite something different!
If I have a raster with 10 Landcover classes (1,2,3,4,5,6,7,8,9,10) and I
want to display only 1,5 and 10, using *Discrete *(1: red, 5: yellow, 10:
blue) the following will happen:
All pixels between 1 and 4 will be red
All pixels between 5 and 9 will be yellow
All pixels with 10 will be blue
In this sense, the pixels are indeed not interpolated, but this still is
not the behavior I am expecting when styling discrete rasters.
A "style discrete raster" function should offer the following:
- Automatically recover all unique values from the raster
- Only display the pixels to which the user has explicitly assigned a
color
But thanks for your hint, this can be helpful in other cases!
Cheers
Stéphane
Le lundi 9 janvier 2017, Enrico Fiore <enricofiore at libero.it> a écrit :
> Hi,
> I think that the solution is in the QGIS documentation, that you can read
> here: http://docs.qgis.org/2.14/en/docs/user_manual/working_with_
> raster/raster_properties.html#band-rendering
> you have to use *Singleband pseudocolor *and set color interpolation to
> Discrete.
> Enrico
> ----Messaggio originale----
> Da: "Stéphane Henriod" <s at henriod.info
> <javascript:_e(%7B%7D,'cvml','s at henriod.info');>>
> Data: 09/01/2017 6.30
> A: "qgis-user"<qgis-user at lists.osgeo.org
> <javascript:_e(%7B%7D,'cvml','qgis-user at lists.osgeo.org');>>
> Ogg: [Qgis-user] Symbolizing a discrete or a boolean raster
> Dear all
> As much as I love QGIS and use it in my everyday life, there is one
> feature that I find particularly annoying: the styling of discrete rasters.
> Basically, if I have a raster layer consisting of discrete landcover
> values (1: water, 2: forest, 3: built-up), it seems that there is no easy
> way to style it. QGIS will assume that the data is continuous and basically
> interpolate the color between each value, which leads to the following
> issues:
> Let's say I want to display only water and built-up (values 1 and 3),
> water in blue and built-up in grey. QGIS will still display the forests,
> using a color somewhere "between" blue and grey. My only left option is to
> process the raster to actually replace all the 2 with NoData, which is
> highly unpractical...
> Same if I have a boolean raster (only 0 and 1 values). QGIS will by
> default make a color ramp from 0 to 0.9999.
> Also, the whole rather feels like a work-around for a missing feature.
> I dream of a feature similar to this one from ArcGIS: http://resources.
> arcgis.com/en/help/main/10.1/index.html#/representing_
> unique_categories_such_as_land_use/009t00000074000000/ where all unique
> values are styled independently and where I can easily skip the values I
> don't want to see on my map.
> I asked a question here:
> http://gis.stackexchange.com/questions/194116/qgis-style-a-discrete-raster
> and opened a ticket here:
> http://hub.qgis.org/issues/14845
> But none has gotten lots of attention yet... Am I the only one to be
> annoyed by this? If no, please raise your hand and let's try to get some
> momentum and see how to push this feature forward!
> Thanks a lot in advance!
> Cheers
> Stéphane
> Stéphane Henriod
> CIM-Expert for GIS and Green Economy Statistics
> Национальный статистический комитет Кыргызской Республики
> Кыргыз Республикасынын Улуттук статистика комитети
> National Statistical Committee of the Kyrgyz Republic
> 374 Фрунзе ул. / Frunze str.
> 720033 Бишкек / Bishkek
> T +996 778 46 99 02 (KG)
> T +49 176 280 11 050 (DE)
> E s at henriod.info <javascript:_e(%7B%7D,'cvml','s at henriod.info');>
> W http://www.stat.kg
> W3W: nightfall.into.bucket
> <https://map.what3words.com/nightfall.into.bucket> // запас.союз.дружный
> <https://map.what3words.com/запас.союз.дружный>
Stéphane Henriod
E s at henriod.info
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/3b69adcd/attachment.html>
