[Qgis-user] Symbolizing a discrete or a boolean raster (Stéphane Henriod)
Richard McDonnell richard.mcdonnell at opw.ie
Tue Jan 10 09:14:41 PST 2017
Harrissou,
Not sure if this is a solution, or if anyone has already given you this
answer, but.... if you know a classified raster has *50* values, which
you wish to style individually, you could try setting*:
  * *Colour Interpolation* to *Linear*
  * *Mode *to*Equal Interval*
  * *Classes *to*51 *(one more than the Max)
I have only just tested this on a raster with 4 values and its worked
for me!
Hope this helps!
Regards,
Richard.
On 10/01/2017 09:49, DelazJ wrote:
> Hi Stéphane,
> 2017-01-10 4:02 GMT+01:00 Stéphane Henriod <s at henriod.info
> <mailto:s at henriod.info>>:
>     Hi Chris
>     this is very nice! I indeed didn't know this trick and will
>     certainly use it again in the future!
>     However... :-)
>     I am currently teaching QGIS to beginners and this for sure is not
>     an appropriate method for them (especially in the case you have to
>     generate the symbology file through a script)!
>     Since the user can style continuous rasters with some
>     "button-clicking", I believe the same option should be available
>     for discrete rasters as well.
>     I am thus wondering if anyone else than me sees it as a priority
>     for QGIS? If yes, how to motivate the developers to take it for
>     the next release and / or how much would such a development cost?
>     (I unfortunately don't have the competences to do it myself)
> There have been some work done in the raster properties dialog in the
> upcoming 3.0. I don't know if your concern was covered though.
> If you want, you can move the question to the developer's list
> <http://qgis.org/en/site/getinvolved/mailinglists.html#qgis-developers-list>
> and discuss whether/how this can be implemented (and its requirements).
> Regards,
> Harrissou
>     Thanks again and cheers!
>     Stéphane
>     Le mardi 10 janvier 2017, Chris House <housec01 at gmail.com
>     <mailto:housec01 at gmail.com>> a écrit :
>         Hi Stéphane,
>         I don't know if this is what you are looking for or not but I
>         have a method of classifying rasters by color based on a set
>         (standard) colors.  I created a spreadsheet that has several
>         required columns, value, red, green, blue...and you can have
>         an optional field for a display value.  So say value 1 is
>         water you can use that last column to name that value so that
>         in the QGIS layer tree and in legend it says Water instead of
>         value 1.
>         save the spreadsheet as a csv and change the extension to .txt
>         instead of .csv.
>         I then go into the symbology section of the raster choose
>         singleband pseudocolor. Use the folder to browse to your text
>         file and click add.  There is a format for this text file.  It
>         is below.  If you need me to email it I will do that in direct
>         email.
>         # QGIS Generated Color Map Export File
>         INTERPOLATION:EXACT
>         -9999,0,0,0,255,NoData
>         0,176,176,176,255,Non-Forested
>         15,234,255,191,255,10 <=  CC < 20
>         25,187,230,149,255,20 <=  CC < 30
>         35,140,201,109,255,30 <=  CC < 40
>         45,98,176,74,255,40 <=  CC < 50
>         55,59,153,43,255,50 <= CC < 60
>         65,0,128,0,255,60 <=  CC < 70
>         75,15,92,11,255,70 <=  CC < 80
>         85,17,61,12,255,80 <=  CC < 90
>         95,16,36,12,255,90 <=  CC <= 100
>         In my example if I don't assign a value it gets ignored by
>         QGIS.  If you are wondering how to assign unique colors to say
>         200 unique values...just script it.  I have done this and as
>         long as you have the number of unique values you want and to
>         make them unique in the script it works.
>         I hope this helps.  I know it isn't a "button" but to be
>         honest I like this better.  If you already knew this...well
>         then maybe it will help someone out in the future.
>         --Chris
>         On Mon, Jan 9, 2017 at 3:00 PM,
>         <qgis-user-request at lists.osgeo.org> wrote:
>             Send Qgis-user mailing list submissions to
>             qgis-user at lists.osgeo.org
>             To subscribe or unsubscribe via the World Wide Web, visit
>             http://lists.osgeo.org/mailman/listinfo/qgis-user
>             <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>             or, via email, send a message with subject or body 'help' to
>             You can reach the person managing the list at
>             qgis-user-owner at lists.osgeo.org
>             When replying, please edit your Subject line so it is more
>             specific
>             than "Re: Contents of Qgis-user digest..."
>             Today's Topics:
>                1. Re: Symbolizing a discrete or a boolean raster
>             (Stéphane Henriod)
>             Message: 1
>             Date: Mon, 9 Jan 2017 23:07:36 +0600
>             From: Stéphane Henriod <s at henriod.info>
>             To: Enrico Fiore <enricofiore at libero.it>
>             Cc: qgis-user <qgis-user at lists.osgeo.org>
>             Subject: Re: [Qgis-user] Symbolizing a discrete or a
>             boolean raster
>             Message-ID:
>             <CAK6pVBXURm_e7dRP+8SP9amPUUX0+Cn3GVxLPNjOHhno85o2rA at mail.gmail.com>
>             Content-Type: text/plain; charset="utf-8"
>             Hi
>             thanks for following up!
>             It actually does part of the job!
>             Using *Color interpretation: Exact*, I can indeed input
>             the exact values I
>             want to display (1,5 and 10) and all other pixels are hidden.
>             HOWEVER,
>             this still feels like a workaround:
>                - In the case of a discrete raster with many (> 50)
>             unique values, I do
>                not want to input all of them manually
>                - In some cases, I do not know in advance all the
>             unique values of my
>                raster
>                - If I click on *Classify*, QGIS will choose X values
>             (based on the
>                number of classes and the classification method
>             (continuous or equal
>                interval)), which no longer match the "exact" values of
>             my raster. It
>                doesn't really make sense to classify a discrete rendering
>             So I would say, we still need a render type "discrete
>             raster" which offers
>             the function to "retrieve all unique values" (and
>             automatically apply a
>             discrete color ramp)
>             Attached a (fake) test dataset.
>             Thanks and cheers
>             Stéphane
>             Le lundi 9 janvier 2017, Enrico Fiore
>             <enricofiore at libero.it> a écrit :
>             > Hi,
>             > Sorry I can't do test, but if you use exact in color
>             interpolation
>             > parameter?
>             > Cheers
>             > Enrico
>             Le lundi 9 janvier 2017, Stéphane Henriod <s at henriod.info>
>             a écrit :
>             > Hi
>             > unfortunately this is doing quite something different!
>             > If I have a raster with 10 Landcover classes
>             (1,2,3,4,5,6,7,8,9,10) and I
>             > want to display only 1,5 and 10, using *Discrete *(1:
>             red, 5: yellow, 10:
>             > blue) the following will happen:
>             > All pixels between 1 and 4 will be red
>             > All pixels between 5 and 9 will be yellow
>             > All pixels with 10 will be blue
>             > In this sense, the pixels are indeed not interpolated,
>             but this still is
>             > not the behavior I am expecting when styling discrete
>             rasters.
>             > A "style discrete raster" function should offer the
>             following:
>             >    - Automatically recover all unique values from the raster
>             >    - Only display the pixels to which the user has
>             explicitly assigned a
>             >    color
>             > But thanks for your hint, this can be helpful in other
>             cases!
>             > Cheers
>             > Stéphane
>             > Le lundi 9 janvier 2017, Enrico Fiore <enricofiore at libero.it
>             > <javascript:_e(%7B%7D,'cvml','enricofiore at libero.it');>>
>             a écrit :
>             >> Hi,
>             >> I think that the solution is in the QGIS documentation,
>             that you can read
>             >> here:
>             http://docs.qgis.org/2.14/en/docs/user_manual/working_with_r
>             <http://docs.qgis.org/2.14/en/docs/user_manual/working_with_r>
>             >> aster/raster_properties.html#band-rendering
>             >> you have to use *Singleband pseudocolor *and set color
>             interpolation to
>             >> Discrete.
>             >> Enrico
>             >> ----Messaggio originale----
>             >> Da: "Stéphane Henriod" <s at henriod.info>
>             >> Data: 09/01/2017 6.30
>             >> A: "qgis-user"<qgis-user at lists.osgeo.org>
>             >> Ogg: [Qgis-user] Symbolizing a discrete or a boolean raster
>             >> Dear all
>             >> As much as I love QGIS and use it in my everyday life,
>             there is one
>             >> feature that I find particularly annoying: the styling
>             of discrete rasters.
>             >> Basically, if I have a raster layer consisting of
>             discrete landcover
>             >> values (1: water, 2: forest, 3: built-up), it seems
>             that there is no easy
>             >> way to style it. QGIS will assume that the data is
>             continuous and basically
>             >> interpolate the color between each value, which leads
>             to the following
>             >> issues:
>             >> Let's say I want to display only water and built-up
>             (values 1 and 3),
>             >> water in blue and built-up in grey. QGIS will still
>             display the forests,
>             >> using a color somewhere "between" blue and grey. My
>             only left option is to
>             >> process the raster to actually replace all the 2 with
>             NoData, which is
>             >> highly unpractical...
>             >> Same if I have a boolean raster (only 0 and 1 values).
>             QGIS will by
>             >> default make a color ramp from 0 to 0.9999.
>             >> Also, the whole rather feels like a work-around for a
>             missing feature.
>             >> I dream of a feature similar to this one from ArcGIS:
>             >> http://resources.arcgis.com/en/help/main/10.1/index
>             <http://resources.arcgis.com/en/help/main/10.1/index>.
>             html#/representing_unique_categories_such_as_land_use/009t00000074000000/
>             >> where all unique values are styled independently and
>             where I can easily
>             >> skip the values I don't want to see on my map.
>             >> I asked a question here:
>             http://gis.stackexchange.com/questions/194116/qgis-style-a-d
>             <http://gis.stackexchange.com/questions/194116/qgis-style-a-d>
>             >> iscrete-raster
>             >> and opened a ticket here:
>             >> http://hub.qgis.org/issues/14845
>             <http://hub.qgis.org/issues/14845>
>             >> But none has gotten lots of attention yet... Am I the
>             only one to be
>             >> annoyed by this? If no, please raise your hand and
>             let's try to get some
>             >> momentum and see how to push this feature forward!
>             >> Thanks a lot in advance!
>             >> Cheers
>             >> Stéphane
>             Stéphane Henriod
>             CIM-Expert for GIS and Green Economy Statistics
>             Национальный статистический комитет Кыргызской Республики
>             Кыргыз Республикасынын Улуттук статистика комитети
>             National Statistical Committee of the Kyrgyz Republic
>             374 Фрунзе ул. / Frunze str.
>             720033 Бишкек / Bishkek
>             T   +996 778 46 99 02 (KG)
>             T +49 176 280 11 050 <tel:+49%20176%2028011050> (DE)
>             E s at henriod.info
>             W http://www.stat.kg
>             W3W: nightfall.into.bucket
>             <https://map.what3words.com/nightfall.into.bucket
>             <https://map.what3words.com/nightfall.into.bucket>> //
>             запас.союз.дружный
>             <https://map.what3words.com/запас.союз.дружный>
>             -------------- next part --------------
>             An HTML attachment was scrubbed...
>             URL:
>             <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.html
>             <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.html>>
>             A non-text attachment was scrubbed...
>             Type: application/zip
>             Desc: not available
>             URL:
>             <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.zip
>             <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.zip>>
>             Subject: Digest Footer
>             _______________________________________________
>             Qgis-user at lists.osgeo.org
>             List info:
>             Unsubscribe:
>             End of Qgis-user Digest, Vol 131, Issue 13
>     Stéphane Henriod
>     E s at henriod.info <mailto:s at henriod.info>
>     <https://map.what3words.com/nightfall.into.bucket>  //
>     запас.союз.дружный
>     <https://map.what3words.com/%D0%B7%D0%B0%D0%BF%D0%B0%D1%81.%D1%81%D0%BE%D1%8E%D0%B7.%D0%B4%D1%80%D1%83%D0%B6%D0%BD%D1%8B%D0%B9>
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170110/5003ca3c/attachment.html>
