[Qgis-user] How to force exact/korrekt editing polygon layer, (topological)
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Jan 11 00:47:31 PST 2017
Hi Bernd,
QGIS can prevent gaps/intersections between polygons of the same layer,
you only have to switch on the options. IMHO QGIS should not always
prevent this because e.g. users may deliberately leave gaps.
So how can you solve your problem?
1) You could teach your users what the options mean and how to use them
(I regularly teach my users).
2) You could further prepare a project for them where the snapping
options are enabled for the layers in question. If you are in PostGIS
create a new DB user that has full rights on these tables and load the
layers with this user account, revoke all editing rights from all other
DB users. Thus your QGIS users can only edit when they use your prepared
project. Be aware that QGIS stores username and password in the project
file, but I would not see a problem in this if your users are as dumb as
you claim :-)
3) If on PostGIS you could enable triggers on insert/update that does
not accept invalid polygons/overlaps between polygons. No way to prevent
gaps during editing; gaps must be identified end eliminated afterwards.
(4) I have never tried PostGIS' new topology. Maybe it is worth checking
it out.
Bernhard
Am 11.01.2017 um 09:24 schrieb Bernd Laskowski:
> Hi Jürgen, what about dumbest assumable user <DAU> or lusers?
> Thanks a lot Harrissou
> but I know the standard options to use topological editing funktions.
> I have problems with foolish users. They forget to activat topological
> editing or snap-option and so on.
> We need a solution to prevent saving intersections or/and holes/gaps
> within qgis or postgis.
> Regards
> Bernd
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
__________ Information from ESET Mail Security, version of virus signature database 14749 (20170111) __________
The message was checked by ESET Mail Security.
http://www.eset.com
