[Qgis-user] Symbolizing a discrete or a boolean raster (Stéphane Henriod)
Nyall Dawson nyall.dawson at gmail.com
Wed Jan 11 16:41:48 PST 2017
On 12 January 2017 at 04:59, Alexandre Neto <senhor.neto at gmail.com> wrote:
> I will share my opinion as I did in the developers list.
> We users are as responsible for QGIS development as the developers. So
> rather than asking what QGIS can do for us, maybe we should think what we
> can do for QGIS. Don't just wait that a volunteer developer decide to spend
> his free time developing a tool that you need.
> IMHO, since it seems that you are not able/willing to sponsor the feature
> yourself, sounds like a good opportunity for a small crowdfunding.
> That way you would be able to contribute back to QGIS by giving your time in
> finding a developer able to do it, setting up the crowdfunding, advertise
> it, pay for part of it and so on.
> It looks like a simple feature. It should not be very expensive (much less
> than an ArcGIS license for sure), and if you think many people need this,
> then the money will be easy to raise. And there is still time to introduce
> this before QGIS 3.0.
Just to add to this - you may find the writeup at
http://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis/
useful as a summary of the different approaches you can take to get
this feature implemented.
What you've done so far is a perfect first step - determining that
there's high demand and lots of interest in your feature!
Nyall
> Best regards,
> Alexandre Neto
> A qua, 11/01/2017, 14:55, Stéphane Henriod <s at henriod.info> escreveu:
>> Thanks for checking, that's what I realized as well!
>> Do you know if there is still a chance to include it for 3.0 or is it too
>> late already?
>> Cheers
>> Stéphane
>> Le mercredi 11 janvier 2017, DelazJ <delazj at gmail.com> a écrit :
>>> Hi Stéphane,
>>> I gave it a look and I'm sorry I was wrong. There have been some work on
>>> the raster classification but it was rather about color and extent
>>> management. See
>>> https://github.com/qgis/QGIS/pulls?utf8=%E2%9C%93&q=is%3Apr%20discrete%20is%3Aclosed%20
>>> or
>>> https://github.com/qgis/QGIS/pulls?utf8=%E2%9C%93&q=is%3Apr%20pseudocolor%20is%3Aclosed%20
>>> but testing upcoming 3.0 shows that nothing has changed in the area you are
>>> interested in.
>>> Harrissou
>>> 2017-01-11 4:37 GMT+01:00 Stéphane Henriod <s at henriod.info>:
>>>> Hi Harrissou
>>>> is there any description / documentation of the work that has been done
>>>> on this (feature description, etc.)? If yes, I'd like to have a look and
>>>> maybe
>>>> Thanks a lot!
>>>> Stéphane
>>>> Le mardi 10 janvier 2017, DelazJ <delazj at gmail.com> a écrit :
>>>>> Hi Stéphane,
>>>>> 2017-01-10 4:02 GMT+01:00 Stéphane Henriod <s at henriod.info>:
>>>>>> Hi Chris
>>>>>> this is very nice! I indeed didn't know this trick and will certainly
>>>>>> use it again in the future!
>>>>>> However... :-)
>>>>>> I am currently teaching QGIS to beginners and this for sure is not an
>>>>>> appropriate method for them (especially in the case you have to generate the
>>>>>> symbology file through a script)!
>>>>>> Since the user can style continuous rasters with some
>>>>>> "button-clicking", I believe the same option should be available for
>>>>>> discrete rasters as well.
>>>>>> I am thus wondering if anyone else than me sees it as a priority for
>>>>>> QGIS? If yes, how to motivate the developers to take it for the next release
>>>>>> and / or how much would such a development cost? (I unfortunately don't have
>>>>>> the competences to do it myself)
>>>>> There have been some work done in the raster properties dialog in the
>>>>> upcoming 3.0. I don't know if your concern was covered though.
>>>>> If you want, you can move the question to the developer's list and
>>>>> discuss whether/how this can be implemented (and its requirements).
>>>>> Regards,
>>>>> Harrissou
>>>>>> Thanks again and cheers!
>>>>>> Stéphane
>>>>>> Le mardi 10 janvier 2017, Chris House <housec01 at gmail.com> a écrit :
>>>>>>> Hi Stéphane,
>>>>>>> I don't know if this is what you are looking for or not but I have a
>>>>>>> method of classifying rasters by color based on a set (standard) colors.  I
>>>>>>> created a spreadsheet that has several required columns, value, red, green,
>>>>>>> blue...and you can have an optional field for a display value.  So say value
>>>>>>> 1 is water you can use that last column to name that value so that in the
>>>>>>> QGIS layer tree and in legend it says Water instead of value 1.
>>>>>>> save the spreadsheet as a csv and change the extension to .txt
>>>>>>> instead of .csv.
>>>>>>> I then go into the symbology section of the raster choose singleband
>>>>>>> pseudocolor. Use the folder to browse to your text file and click add.
>>>>>>> There is a format for this text file.  It is below.  If you need me to email
>>>>>>> it I will do that in direct email.
>>>>>>> # QGIS Generated Color Map Export File
>>>>>>> INTERPOLATION:EXACT
>>>>>>> -9999,0,0,0,255,NoData
>>>>>>> 0,176,176,176,255,Non-Forested
>>>>>>> 15,234,255,191,255,10 <=  CC < 20
>>>>>>> 25,187,230,149,255,20 <=  CC < 30
>>>>>>> 35,140,201,109,255,30 <=  CC < 40
>>>>>>> 45,98,176,74,255,40 <=  CC < 50
>>>>>>> 55,59,153,43,255,50 <= CC < 60
>>>>>>> 65,0,128,0,255,60 <=  CC < 70
>>>>>>> 75,15,92,11,255,70 <=  CC < 80
>>>>>>> 85,17,61,12,255,80 <=  CC < 90
>>>>>>> 95,16,36,12,255,90 <=  CC <= 100
>>>>>>> In my example if I don't assign a value it gets ignored by QGIS.  If
>>>>>>> you are wondering how to assign unique colors to say 200 unique
>>>>>>> values...just script it.  I have done this and as long as you have the
>>>>>>> number of unique values you want and to make them unique in the script it
>>>>>>> works.
>>>>>>> I hope this helps.  I know it isn't a "button" but to be honest I
>>>>>>> like this better.  If you already knew this...well then maybe it will help
>>>>>>> someone out in the future.
>>>>>>> --Chris
>>>>>>> On Mon, Jan 9, 2017 at 3:00 PM, <qgis-user-request at lists.osgeo.org>
>>>>>>> wrote:
>>>>>>>> Send Qgis-user mailing list submissions to
>>>>>>>>         qgis-user at lists.osgeo.org
>>>>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>>>>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> or, via email, send a message with subject or body 'help' to
>>>>>>>> You can reach the person managing the list at
>>>>>>>>         qgis-user-owner at lists.osgeo.org
>>>>>>>> When replying, please edit your Subject line so it is more specific
>>>>>>>> than "Re: Contents of Qgis-user digest..."
>>>>>>>> Today's Topics:
>>>>>>>>    1. Re: Symbolizing a discrete or a boolean raster (Stéphane
>>>>>>>> Henriod)
>>>>>>>> Message: 1
>>>>>>>> Date: Mon, 9 Jan 2017 23:07:36 +0600
>>>>>>>> From: Stéphane Henriod <s at henriod.info>
>>>>>>>> To: Enrico Fiore <enricofiore at libero.it>
>>>>>>>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>>>>>>>> Subject: Re: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>>>>> Message-ID:
>>>>>>>> <CAK6pVBXURm_e7dRP+8SP9amPUUX0+Cn3GVxLPNjOHhno85o2rA at mail.gmail.com>
>>>>>>>> Content-Type: text/plain; charset="utf-8"
>>>>>>>> Hi
>>>>>>>> thanks for following up!
>>>>>>>> It actually does part of the job!
>>>>>>>> Using *Color interpretation: Exact*, I can indeed input the exact
>>>>>>>> values I
>>>>>>>> want to display (1,5 and 10) and all other pixels are hidden.
>>>>>>>> HOWEVER,
>>>>>>>> this still feels like a workaround:
>>>>>>>>    - In the case of a discrete raster with many (> 50) unique
>>>>>>>> values, I do
>>>>>>>>    not want to input all of them manually
>>>>>>>>    - In some cases, I do not know in advance all the unique values
>>>>>>>> of my
>>>>>>>>    raster
>>>>>>>>    - If I click on *Classify*, QGIS will choose X values (based on
>>>>>>>> the
>>>>>>>>    number of classes and the classification method (continuous or
>>>>>>>> equal
>>>>>>>>    interval)), which no longer match the "exact" values of my
>>>>>>>> raster. It
>>>>>>>>    doesn't really make sense to classify a discrete rendering
>>>>>>>> So I would say, we still need a render type "discrete raster" which
>>>>>>>> offers
>>>>>>>> the function to "retrieve all unique values" (and automatically
>>>>>>>> apply a
>>>>>>>> discrete color ramp)
>>>>>>>> Attached a (fake) test dataset.
>>>>>>>> Thanks and cheers
>>>>>>>> Stéphane
>>>>>>>> Le lundi 9 janvier 2017, Enrico Fiore <enricofiore at libero.it> a
>>>>>>>> écrit :
>>>>>>>> > Hi,
>>>>>>>> > Sorry I can't do test, but if you use exact in color interpolation
>>>>>>>> > parameter?
>>>>>>>> > Cheers
>>>>>>>> > Enrico
>>>>>>>> Le lundi 9 janvier 2017, Stéphane Henriod <s at henriod.info> a écrit :
>>>>>>>> > Hi
>>>>>>>> > unfortunately this is doing quite something different!
>>>>>>>> > If I have a raster with 10 Landcover classes
>>>>>>>> > (1,2,3,4,5,6,7,8,9,10) and I
>>>>>>>> > want to display only 1,5 and 10, using *Discrete *(1: red, 5:
>>>>>>>> > yellow, 10:
>>>>>>>> > blue) the following will happen:
>>>>>>>> > All pixels between 1 and 4 will be red
>>>>>>>> > All pixels between 5 and 9 will be yellow
>>>>>>>> > All pixels with 10 will be blue
>>>>>>>> > In this sense, the pixels are indeed not interpolated, but this
>>>>>>>> > still is
>>>>>>>> > not the behavior I am expecting when styling discrete rasters.
>>>>>>>> > A "style discrete raster" function should offer the following:
>>>>>>>> >    - Automatically recover all unique values from the raster
>>>>>>>> >    - Only display the pixels to which the user has explicitly
>>>>>>>> > assigned a
>>>>>>>> >    color
>>>>>>>> > But thanks for your hint, this can be helpful in other cases!
>>>>>>>> > Cheers
>>>>>>>> > Stéphane
>>>>>>>> > <javascript:_e(%7B%7D,'cvml','enricofiore at libero.it');>> a écrit :
>>>>>>>> >> Hi,
>>>>>>>> >> I think that the solution is in the QGIS documentation, that you
>>>>>>>> >> can read
>>>>>>>> >> here:
>>>>>>>> >> http://docs.qgis.org/2.14/en/docs/user_manual/working_with_r
>>>>>>>> >> aster/raster_properties.html#band-rendering
>>>>>>>> >> you have to use *Singleband pseudocolor *and set color
>>>>>>>> >> interpolation to
>>>>>>>> >> Discrete.
>>>>>>>> >> Enrico
>>>>>>>> >> ----Messaggio originale----
>>>>>>>> >> Da: "Stéphane Henriod" <s at henriod.info>
>>>>>>>> >> Data: 09/01/2017 6.30
>>>>>>>> >> A: "qgis-user"<qgis-user at lists.osgeo.org>
>>>>>>>> >> Ogg: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>>>>> >> Dear all
>>>>>>>> >> As much as I love QGIS and use it in my everyday life, there is
>>>>>>>> >> one
>>>>>>>> >> feature that I find particularly annoying: the styling of
>>>>>>>> >> discrete rasters.
>>>>>>>> >> Basically, if I have a raster layer consisting of discrete
>>>>>>>> >> landcover
>>>>>>>> >> values (1: water, 2: forest, 3: built-up), it seems that there is
>>>>>>>> >> no easy
>>>>>>>> >> way to style it. QGIS will assume that the data is continuous and
>>>>>>>> >> basically
>>>>>>>> >> interpolate the color between each value, which leads to the
>>>>>>>> >> following
>>>>>>>> >> issues:
>>>>>>>> >> Let's say I want to display only water and built-up (values 1 and
>>>>>>>> >> 3),
>>>>>>>> >> water in blue and built-up in grey. QGIS will still display the
>>>>>>>> >> forests,
>>>>>>>> >> using a color somewhere "between" blue and grey. My only left
>>>>>>>> >> option is to
>>>>>>>> >> process the raster to actually replace all the 2 with NoData,
>>>>>>>> >> which is
>>>>>>>> >> highly unpractical...
>>>>>>>> >> Same if I have a boolean raster (only 0 and 1 values). QGIS will
>>>>>>>> >> by
>>>>>>>> >> default make a color ramp from 0 to 0.9999.
>>>>>>>> >> Also, the whole rather feels like a work-around for a missing
>>>>>>>> >> feature.
>>>>>>>> >> I dream of a feature similar to this one from ArcGIS:
>>>>>>>> >> http://resources.arcgis.com/en/help/main/10.1/index.
>>>>>>>> >> html#/representing_unique_categories_such_as_land_use/009t00000074000000/
>>>>>>>> >> where all unique values are styled independently and where I can
>>>>>>>> >> easily
>>>>>>>> >> skip the values I don't want to see on my map.
>>>>>>>> >> I asked a question here:
>>>>>>>> >> http://gis.stackexchange.com/questions/194116/qgis-style-a-d
>>>>>>>> >> iscrete-raster
>>>>>>>> >> and opened a ticket here:
>>>>>>>> >> http://hub.qgis.org/issues/14845
>>>>>>>> >> But none has gotten lots of attention yet... Am I the only one to
>>>>>>>> >> be
>>>>>>>> >> annoyed by this? If no, please raise your hand and let's try to
>>>>>>>> >> get some
>>>>>>>> >> momentum and see how to push this feature forward!
>>>>>>>> >> Thanks a lot in advance!
>>>>>>>> >> Cheers
>>>>>>>> >> Stéphane
>>>>>>>> Stéphane Henriod
>>>>>>>> CIM-Expert for GIS and Green Economy Statistics
>>>>>>>> Национальный статистический комитет Кыргызской Республики
>>>>>>>> Кыргыз Республикасынын Улуттук статистика комитети
>>>>>>>> National Statistical Committee of the Kyrgyz Republic
>>>>>>>> 374 Фрунзе ул. / Frunze str.
>>>>>>>> 720033 Бишкек / Bishkek
>>>>>>>> T   +996 778 46 99 02 (KG)
>>>>>>>> T   +49 176 280 11 050 (DE)
>>>>>>>> E    s at henriod.info
>>>>>>>> W   http://www.stat.kg
>>>>>>>> W3W: nightfall.into.bucket
>>>>>>>> <https://map.what3words.com/nightfall.into.bucket>  //
>>>>>>>> запас.союз.дружный
>>>>>>>> <https://map.what3words.com/запас.союз.дружный>
>>>>>>>> -------------- next part --------------
>>>>>>>> An HTML attachment was scrubbed...
>>>>>>>> URL:
>>>>>>>> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.html>
>>>>>>>> A non-text attachment was scrubbed...
>>>>>>>> Type: application/zip
>>>>>>>> Desc: not available
>>>>>>>> URL:
>>>>>>>> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.zip>
>>>>>>>> Subject: Digest Footer
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> End of Qgis-user Digest, Vol 131, Issue 13
>>>>>> Stéphane Henriod
>>>>>> E    s at henriod.info
>>>>>> W3W: nightfall.into.bucket  //  запас.союз.дружный
>>>> Stéphane Henriod
>>>> E    s at henriod.info
>> Stéphane Henriod
>> E    s at henriod.info
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
