[Qgis-user] Symbolizing a discrete or a boolean raster (Stéphane Henriod)
Stéphane Henriod
s at henriod.info
Thu Jan 12 02:45:48 PST 2017
Hi all
upon advice from Andreas, I started a formal description of the
requirements for such a feature:
https://docs.google.com/document/d/1cDemM2m88_mbs65sYzfBbVdHI_ObOjf_i35ne3OKsRs/edit?usp=sharing
Please, anyone interested, do check, comment, add, correct,... Once we have
a "final" version, I will inquire a more precise financial estimation. Then
let's see how we can move forward!
Thanks and cheers
Stéphane
Le jeudi 12 janvier 2017, Stéphane Henriod <s at henriod.info> a écrit :
> Hi Alexandre
> (also posting on dev-)
> I 100% agree with you and I would love to somehow give back to QGIS (I did
> already, but at a small scale).
> I mostly wanted to know if I am the only one to wish for this feature.
> Apparently not the case: many have expressed the same wish!
> Now funding: I would love to have a rough idea what "not very expensive"
> means. If there are any dev around who could have the interest / skills to
> implement this feature, can we somehow go concrete and work together on a
> feature description and tentative budget? The situation is obviously very
> different if we talk about 1.000 or 20.000€
> And thanks Nyall for your amazing overview. That indeed makes things much
> clearer to me!
> Cheers
> Stéphane
> Le jeudi 12 janvier 2017, Alexandre Neto <senhor.neto at gmail.com
> <javascript:_e(%7B%7D,'cvml','senhor.neto at gmail.com');>> a écrit :
>> I will share my opinion as I did in the developers list.
>> We users are as responsible for QGIS development as the developers. So
>> rather than asking what QGIS can do for us, maybe we should think what we
>> can do for QGIS. Don't just wait that a volunteer developer decide to spend
>> his free time developing a tool that you need.
>> IMHO, since it seems that you are not able/willing to sponsor the feature
>> yourself, sounds like a good opportunity for a small crowdfunding.
>> That way you would be able to contribute back to QGIS by giving your time
>> in finding a developer able to do it, setting up the crowdfunding,
>> advertise it, pay for part of it and so on.
>> It looks like a simple feature. It should not be very expensive (much
>> less than an ArcGIS license for sure), and if you think many people need
>> this, then the money will be easy to raise. And there is still time to
>> introduce this before QGIS 3.0.
>> Best regards,
>> Alexandre Neto
>> A qua, 11/01/2017, 14:55, Stéphane Henriod <s at henriod.info> escreveu:
>>> Thanks for checking, that's what I realized as well!
>>> Do you know if there is still a chance to include it for 3.0 or is it
>>> too late already?
>>> Cheers
>>> Stéphane
>>> Le mercredi 11 janvier 2017, DelazJ <delazj at gmail.com> a écrit :
>>>> Hi Stéphane,
>>>> I gave it a look and I'm sorry I was wrong. There have been some work
>>>> on the raster classification but it was rather about color and extent
>>>> management. See https://github.com/qgis/QGIS/p
>>>> ulls?utf8=%E2%9C%93&q=is%3Apr%20discrete%20is%3Aclosed%20 or
>>>> https://github.com/qgis/QGIS/pulls?utf8=%E2%9C%93&q=is%3Apr%
>>>> 20pseudocolor%20is%3Aclosed%20 but testing upcoming 3.0 shows that
>>>> nothing has changed in the area you are interested in.
>>>> Harrissou
>>>> 2017-01-11 4:37 GMT+01:00 Stéphane Henriod <s at henriod.info>:
>>>>> Hi Harrissou
>>>>> is there any description / documentation of the work that has been
>>>>> done on this (feature description, etc.)? If yes, I'd like to have a look
>>>>> and maybe
>>>>> Thanks a lot!
>>>>> Stéphane
>>>>> Le mardi 10 janvier 2017, DelazJ <delazj at gmail.com> a écrit :
>>>>>> Hi Stéphane,
>>>>>> 2017-01-10 4:02 GMT+01:00 Stéphane Henriod <s at henriod.info>:
>>>>>>> Hi Chris
>>>>>>> this is very nice! I indeed didn't know this trick and will
>>>>>>> certainly use it again in the future!
>>>>>>> However... :-)
>>>>>>> I am currently teaching QGIS to beginners and this for sure is not
>>>>>>> an appropriate method for them (especially in the case you have to generate
>>>>>>> the symbology file through a script)!
>>>>>>> Since the user can style continuous rasters with some
>>>>>>> "button-clicking", I believe the same option should be available for
>>>>>>> discrete rasters as well.
>>>>>>> I am thus wondering if anyone else than me sees it as a priority for
>>>>>>> QGIS? If yes, how to motivate the developers to take it for the next
>>>>>>> release and / or how much would such a development cost? (I unfortunately
>>>>>>> don't have the competences to do it myself)
>>>>>>> There have been some work done in the raster properties dialog in
>>>>>> the upcoming 3.0. I don't know if your concern was covered though.
>>>>>> If you want, you can move the question to the developer's list
>>>>>> <http://qgis.org/en/site/getinvolved/mailinglists.html#qgis-developers-list>
>>>>>> and discuss whether/how this can be implemented (and its requirements).
>>>>>> Regards,
>>>>>> Harrissou
>>>>>> Thanks again and cheers!
>>>>>>> Stéphane
>>>>>>> Le mardi 10 janvier 2017, Chris House <housec01 at gmail.com> a écrit :
>>>>>>>> Hi Stéphane,
>>>>>>>> I don't know if this is what you are looking for or not but I have
>>>>>>>> a method of classifying rasters by color based on a set (standard) colors.
>>>>>>>> I created a spreadsheet that has several required columns, value, red,
>>>>>>>> green, blue...and you can have an optional field for a display value. So
>>>>>>>> say value 1 is water you can use that last column to name that value so
>>>>>>>> that in the QGIS layer tree and in legend it says Water instead of value
>>>>>>>> 1.
>>>>>>>> save the spreadsheet as a csv and change the extension to .txt
>>>>>>>> instead of .csv.
>>>>>>>> I then go into the symbology section of the raster choose
>>>>>>>> singleband pseudocolor. Use the folder to browse to your text file and
>>>>>>>> click add. There is a format for this text file. It is below. If you
>>>>>>>> need me to email it I will do that in direct email.
>>>>>>>> # QGIS Generated Color Map Export File
>>>>>>>> INTERPOLATION:EXACT
>>>>>>>> -9999,0,0,0,255,NoData
>>>>>>>> 0,176,176,176,255,Non-Forested
>>>>>>>> 15,234,255,191,255,10 <= CC < 20
>>>>>>>> 25,187,230,149,255,20 <= CC < 30
>>>>>>>> 35,140,201,109,255,30 <= CC < 40
>>>>>>>> 45,98,176,74,255,40 <= CC < 50
>>>>>>>> 55,59,153,43,255,50 <= CC < 60
>>>>>>>> 65,0,128,0,255,60 <= CC < 70
>>>>>>>> 75,15,92,11,255,70 <= CC < 80
>>>>>>>> 85,17,61,12,255,80 <= CC < 90
>>>>>>>> 95,16,36,12,255,90 <= CC <= 100
>>>>>>>> In my example if I don't assign a value it gets ignored by QGIS.
>>>>>>>> If you are wondering how to assign unique colors to say 200 unique
>>>>>>>> values...just script it. I have done this and as long as you have the
>>>>>>>> number of unique values you want and to make them unique in the script it
>>>>>>>> works.
>>>>>>>> I hope this helps. I know it isn't a "button" but to be honest I
>>>>>>>> like this better. If you already knew this...well then maybe it will help
>>>>>>>> someone out in the future.
>>>>>>>> --Chris
>>>>>>>> On Mon, Jan 9, 2017 at 3:00 PM, <qgis-user-request at lists.osgeo.org>
>>>>>>>> wrote:
>>>>>>>>> Send Qgis-user mailing list submissions to
>>>>>>>>> qgis-user at lists.osgeo.org
>>>>>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> or, via email, send a message with subject or body 'help' to
>>>>>>>>> You can reach the person managing the list at
>>>>>>>>> qgis-user-owner at lists.osgeo.org
>>>>>>>>> When replying, please edit your Subject line so it is more specific
>>>>>>>>> than "Re: Contents of Qgis-user digest..."
>>>>>>>>> Today's Topics:
>>>>>>>>> 1. Re: Symbolizing a discrete or a boolean raster (Stéphane
>>>>>>>>> Henriod)
>>>>>>>>> Message: 1
>>>>>>>>> Date: Mon, 9 Jan 2017 23:07:36 +0600
>>>>>>>>> From: Stéphane Henriod <s at henriod.info>
>>>>>>>>> To: Enrico Fiore <enricofiore at libero.it>
>>>>>>>>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>>>>>>>>> Subject: Re: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>>>>>> Message-ID:
>>>>>>>>> <CAK6pVBXURm_e7dRP+8SP9amPUUX0
>>>>>>>>> +Cn3GVxLPNjOHhno85o2rA at mail.gmail.com>
>>>>>>>>> Content-Type: text/plain; charset="utf-8"
>>>>>>>>> Hi
>>>>>>>>> thanks for following up!
>>>>>>>>> It actually does part of the job!
>>>>>>>>> Using *Color interpretation: Exact*, I can indeed input the exact
>>>>>>>>> values I
>>>>>>>>> want to display (1,5 and 10) and all other pixels are hidden.
>>>>>>>>> HOWEVER,
>>>>>>>>> this still feels like a workaround:
>>>>>>>>> - In the case of a discrete raster with many (> 50) unique
>>>>>>>>> values, I do
>>>>>>>>> not want to input all of them manually
>>>>>>>>> - In some cases, I do not know in advance all the unique values
>>>>>>>>> of my
>>>>>>>>> raster
>>>>>>>>> - If I click on *Classify*, QGIS will choose X values (based on
>>>>>>>>> the
>>>>>>>>> number of classes and the classification method (continuous or
>>>>>>>>> equal
>>>>>>>>> interval)), which no longer match the "exact" values of my
>>>>>>>>> raster. It
>>>>>>>>> doesn't really make sense to classify a discrete rendering
>>>>>>>>> So I would say, we still need a render type "discrete raster"
>>>>>>>>> which offers
>>>>>>>>> the function to "retrieve all unique values" (and automatically
>>>>>>>>> apply a
>>>>>>>>> discrete color ramp)
>>>>>>>>> Attached a (fake) test dataset.
>>>>>>>>> Thanks and cheers
>>>>>>>>> Stéphane
>>>>>>>>> Le lundi 9 janvier 2017, Enrico Fiore <enricofiore at libero.it> a
>>>>>>>>> écrit :
>>>>>>>>> > Hi,
>>>>>>>>> > Sorry I can't do test, but if you use exact in color
>>>>>>>>> interpolation
>>>>>>>>> > parameter?
>>>>>>>>> > Cheers
>>>>>>>>> > Enrico
>>>>>>>>> Le lundi 9 janvier 2017, Stéphane Henriod <s at henriod.info> a
>>>>>>>>> écrit :
>>>>>>>>> > Hi
>>>>>>>>> > unfortunately this is doing quite something different!
>>>>>>>>> > If I have a raster with 10 Landcover classes
>>>>>>>>> (1,2,3,4,5,6,7,8,9,10) and I
>>>>>>>>> > want to display only 1,5 and 10, using *Discrete *(1: red, 5:
>>>>>>>>> yellow, 10:
>>>>>>>>> > blue) the following will happen:
>>>>>>>>> > All pixels between 1 and 4 will be red
>>>>>>>>> > All pixels between 5 and 9 will be yellow
>>>>>>>>> > All pixels with 10 will be blue
>>>>>>>>> > In this sense, the pixels are indeed not interpolated, but this
>>>>>>>>> still is
>>>>>>>>> > not the behavior I am expecting when styling discrete rasters.
>>>>>>>>> > A "style discrete raster" function should offer the following:
>>>>>>>>> > - Automatically recover all unique values from the raster
>>>>>>>>> > - Only display the pixels to which the user has explicitly
>>>>>>>>> assigned a
>>>>>>>>> > color
>>>>>>>>> > But thanks for your hint, this can be helpful in other cases!
>>>>>>>>> > Cheers
>>>>>>>>> > Stéphane
>>>>>>>>> > <javascript:_e(%7B%7D,'cvml','enricofiore at libero.it');>> a
>>>>>>>>> écrit :
>>>>>>>>> >> Hi,
>>>>>>>>> >> I think that the solution is in the QGIS documentation, that
>>>>>>>>> you can read
>>>>>>>>> >> here: http://docs.qgis.org/2.14/en/d
>>>>>>>>> ocs/user_manual/working_with_r
>>>>>>>>> >> aster/raster_properties.html#band-rendering
>>>>>>>>> >> you have to use *Singleband pseudocolor *and set color
>>>>>>>>> interpolation to
>>>>>>>>> >> Discrete.
>>>>>>>>> >> Enrico
>>>>>>>>> >> ----Messaggio originale----
>>>>>>>>> >> Da: "Stéphane Henriod" <s at henriod.info>
>>>>>>>>> >> Data: 09/01/2017 6.30
>>>>>>>>> >> A: "qgis-user"<qgis-user at lists.osgeo.org>
>>>>>>>>> >> Ogg: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>>>>>> >> Dear all
>>>>>>>>> >> As much as I love QGIS and use it in my everyday life, there is
>>>>>>>>> one
>>>>>>>>> >> feature that I find particularly annoying: the styling of
>>>>>>>>> discrete rasters.
>>>>>>>>> >> Basically, if I have a raster layer consisting of discrete
>>>>>>>>> landcover
>>>>>>>>> >> values (1: water, 2: forest, 3: built-up), it seems that there
>>>>>>>>> is no easy
>>>>>>>>> >> way to style it. QGIS will assume that the data is continuous
>>>>>>>>> and basically
>>>>>>>>> >> interpolate the color between each value, which leads to the
>>>>>>>>> following
>>>>>>>>> >> issues:
>>>>>>>>> >> Let's say I want to display only water and built-up (values 1
>>>>>>>>> and 3),
>>>>>>>>> >> water in blue and built-up in grey. QGIS will still display the
>>>>>>>>> forests,
>>>>>>>>> >> using a color somewhere "between" blue and grey. My only left
>>>>>>>>> option is to
>>>>>>>>> >> process the raster to actually replace all the 2 with NoData,
>>>>>>>>> which is
>>>>>>>>> >> highly unpractical...
>>>>>>>>> >> Same if I have a boolean raster (only 0 and 1 values). QGIS
>>>>>>>>> will by
>>>>>>>>> >> default make a color ramp from 0 to 0.9999.
>>>>>>>>> >> Also, the whole rather feels like a work-around for a missing
>>>>>>>>> feature.
>>>>>>>>> >> I dream of a feature similar to this one from ArcGIS:
>>>>>>>>> >> http://resources.arcgis.com/en/help/main/10.1/index.
>>>>>>>>> >> html#/representing_unique_categories_such_as_land_use/009t00
>>>>>>>>> 000074000000/
>>>>>>>>> >> where all unique values are styled independently and where I
>>>>>>>>> can easily
>>>>>>>>> >> skip the values I don't want to see on my map.
>>>>>>>>> >> I asked a question here:
>>>>>>>>> >> http://gis.stackexchange.com/questions/194116/qgis-style-a-d
>>>>>>>>> >> iscrete-raster
>>>>>>>>> >> and opened a ticket here:
>>>>>>>>> >> http://hub.qgis.org/issues/14845
>>>>>>>>> >> But none has gotten lots of attention yet... Am I the only one
>>>>>>>>> to be
>>>>>>>>> >> annoyed by this? If no, please raise your hand and let's try to
>>>>>>>>> get some
>>>>>>>>> >> momentum and see how to push this feature forward!
>>>>>>>>> >> Thanks a lot in advance!
>>>>>>>>> >> Cheers
>>>>>>>>> >> Stéphane
>>>>>>>>> Stéphane Henriod
>>>>>>>>> CIM-Expert for GIS and Green Economy Statistics
>>>>>>>>> Национальный статистический комитет Кыргызской Республики
>>>>>>>>> Кыргыз Республикасынын Улуттук статистика комитети
>>>>>>>>> National Statistical Committee of the Kyrgyz Republic
>>>>>>>>> 374 Фрунзе ул. / Frunze str.
>>>>>>>>> 720033 Бишкек / Bishkek
>>>>>>>>> T +996 778 46 99 02 (KG)
>>>>>>>>> T +49 176 280 11 050 <+49%20176%2028011050> (DE)
>>>>>>>>> E s at henriod.info
>>>>>>>>> W http://www.stat.kg
>>>>>>>>> W3W: nightfall.into.bucket
>>>>>>>>> <https://map.what3words.com/nightfall.into.bucket> //
>>>>>>>>> запас.союз.дружный
>>>>>>>>> <https://map.what3words.com/запас.союз.дружный>
>>>>>>>>> -------------- next part --------------
>>>>>>>>> An HTML attachment was scrubbed...
>>>>>>>>> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/
>>>>>>>>> 20170109/985fd14c/attachment-0001.html>
>>>>>>>>> A non-text attachment was scrubbed...
>>>>>>>>> Type: application/zip
>>>>>>>>> Desc: not available
>>>>>>>>> 20170109/985fd14c/attachment-0001.zip>
>>>>>>>>> Subject: Digest Footer
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> End of Qgis-user Digest, Vol 131, Issue 13
>>>>>>> Stéphane Henriod
>>>>>>> E s at henriod.info
>>>>>>> запас.союз.дружный <https://map.what3words.com/запас.союз.дружный>
>>>>> Stéphane Henriod
>>>>> E s at henriod.info
>>> Stéphane Henriod
>>> T +49 176 280 11 050 (DE)
>>> E s at henriod.info
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
> Stéphane Henriod
> E s at henriod.info <javascript:_e(%7B%7D,'cvml','s at henriod.info');>
> <https://map.what3words.com/nightfall.into.bucket> // запас.союз.дружный
Stéphane Henriod
E s at henriod.info
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170112/295c0709/attachment.html>
