[Qgis-user] can't editing view using rules
Luca Lanteri
lklanteri at gmail.com
Fri Jan 13 07:39:24 PST 2017
Hi to all,
starting fron QIS 2.16 I can't edit anymore postgres views with rules. When
I try to insert a new feature I have this error [0]. All works fine with
QGIS 2.14
Can anyone confirm the issue ?
Thanks
Luca
[0]
Impossibile applicare le modifiche al vettore v_frane_pol_full
Errori: ERRORE: 1 geometria non aggiunta.
Errori della sorgente dati:
Errore PostGIS nell'aggiunta delle geometrie: ERROR: cannot perform INSERT
RETURNING on relation "v_frane_pol_full"
HINT: You need an unconditional ON INSERT DO INSTEAD rule with a RETURNING
clause.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170113/ef83557b/attachment.html>
