[Qgis-user] QGIS 2.18.2 can not see GRASS data / use GRASS algorithms
Stephane Goldstein s.n.g at gmx.com
Fri Jan 13 09:10:56 PST 2017
Hi.
This also started happening to me after upgrading to 2.18.2.
If you open QGIS in the command line, then try to run a GRASS tool from
Processing, you will probably see a message saying that it couldn't find
grass70.
Because you're using ubuntugis-unstable, you probably have GRASS 7.2, so
this should be the reason fro the error.
Switching from ubuntugis-unstable to ubuntugis-stable, which has GRASS 7.0,
did the trick for me.
Not sure if there is another way to fix this while using ubuntugis-unstable
/ GRASS 7.2, without compiling QGIS from source.
Any ideas ?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170113/144a0681/attachment.html>
