[Qgis-user] Non-Earth Coordinates
Michael Treglia
mtreglia at gmail.com
Mon Jan 16 18:21:59 PST 2017
Hi Grant - good question. Looks like a similar question came up on Stack
Exchange last spring. Does it sound like this answer works for you?
http://gis.stackexchange.com/questions/187699/how-to-create-a-qgis-map-of-unprojected-data
(Ultimately the suggestion is to assign it to a UTM or foot based
coordinate system, as that should work fine for display and such - if you
find out there is a real Geographic coordinate system later, you can just
assign as appropriate).
If not, curious to hear more about the specific case you're dealing with.
mike
On Mon, Jan 16, 2017 at 9:10 PM, Grant Boxer <boxerg at iinet.net.au> wrote:
> Is there an option in QGIS to select a non-earth coordinate system? This
> is useful when you get data in a local grid without a readily available
> conversion to real earth coordinates. There is this option in MapInfo and
> it is really handy when dealing with old data. The “local grid” can then be
> transformed later when a conversion can be determined.
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170116/16626df8/attachment.html>
