[Qgis-user] can't editing view using rules
Karl-Magnus Jönsson
Karl-Magnus.Jonsson at kristianstad.se
Tue Jan 17 01:41:37 PST 2017
Hi!
Ok. When I try another view with an INSERT rule I have the same problem in 2.18.2. Works in 2.14. UPDATE and DELETE are ok as well. Can we check the resulting SQL from QGIS? Must be some difference there. I don’t know if we can turn on logging on our database.
Karl-Magnus Jönsson
Från: mescal72 at gmail.com [mailto:mescal72 at gmail.com] För Luca Lanteri
Skickat: den 16 januari 2017 14:44
Till: Karl-Magnus Jönsson
Kopia: qgis-user
Ämne: Re: [Qgis-user] can't editing view using rules
Hi Magnus, thanks for the answer.
I think my rules are ok also because they work fine with QGIS 2.14.
The strange things is that the error say about an "INSERT RETURNING" when I don't need any RETURING clause.
The problem happens only with INSERT rules. UPDATE and DELETE are ok.
this is my INSERT rule:
CREATE OR REPLACE RULE dif_spon_insert AS
ON INSERT TO sicod.v_dif_spon DO INSTEAD INSERT INTO sicod.dif_spon (padr_id, sigla_rile, prog_opera, localita, sponda, alt_min, alt_max, lung, tipologia, efficienza, stato, mat_massi, mat_c_secc, mat_c_int, mat_a_secc, mat_a_int, mat_gabbio, mat_cls, mat_legna, i_manuten, i_nessuna, i_prolung, i_pulizia, i_ricostru, i_sottomur, i_svuotam, so_dissest, so_interra, so_scalzat, so_sifonat, note, data_rilev, desc_fonte, font_elab, font_sopr, font_altro, geom)
VALUES (new.padr_id, new.sigla_rile, new.prog_opera, new.localita, new.sponda, new.alt_min, new.alt_max, new.lung, new.tipologia, new.efficienza, new.stato, new.mat_massi, new.mat_c_secc, new.mat_c_int, new.mat_a_secc, new.mat_a_int, new.mat_gabbio, new.mat_cls, new.mat_legna, new.i_manuten, new.i_nessuna, new.i_prolung, new.i_pulizia, new.i_ricostru, new.i_sottomur, new.i_svuotam, new.so_dissest, new.so_interra, new.so_scalzat, new.so_sifonat, new.note, new.data_rilev, new.desc_fonte, new.font_elab, new.font_sopr, new.font_altro, new.geom);
2017-01-16 7:56 GMT+01:00 Karl-Magnus Jönsson <Karl-Magnus.Jonsson at kristianstad.se<mailto:Karl-Magnus.Jonsson at kristianstad.se>>:
Hi!
Are you sure it isn’t an issue with the view? I have a view with rules and it work in 2.18. When you have conditions in the rule you must have another rule on the same event that is unconditional. Check the last paragraph in the description : https://www.postgresql.org/docs/current/static/sql-createrule.html
In my case I have a unconditional rule that does nothing:
CREATE OR REPLACE RULE v_prislistor_upd_ins AS
ON UPDATE TO park.v_prislistor
WHERE old.id<http://old.id> IS NULL DO INSTEAD INSERT INTO park.priser (kod, pris, utforare)
VALUES (new.kod, new.pris, new.utforare);
CREATE OR REPLACE RULE v_prislistor_upd_nothing AS
ON UPDATE TO park.v_prislistor DO INSTEAD NOTHING;
CREATE OR REPLACE RULE v_prislistor_upd_upd AS
WHERE old.id<http://old.id> IS NOT NULL DO INSTEAD UPDATE park.priser SET pris = new.pris
WHERE priser.id<http://priser.id> = old.id<http://old.id>;
Karl-Magnus Jönsson
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] För Luca Lanteri
Skickat: den 13 januari 2017 16:39
Till: qgis-user
Ämne: [Qgis-user] can't editing view using rules
Hi to all,
starting fron QIS 2.16 I can't edit anymore postgres views with rules. When I try to insert a new feature I have this error [0]. All works fine with QGIS 2.14
Can anyone confirm the issue ?
Thanks
Luca
[0]
Impossibile applicare le modifiche al vettore v_frane_pol_full
Errori: ERRORE: 1 geometria non aggiunta.
Errori della sorgente dati:
Errore PostGIS nell'aggiunta delle geometrie: ERROR: cannot perform INSERT RETURNING on relation "v_frane_pol_full"
HINT: You need an unconditional ON INSERT DO INSTEAD rule with a RETURNING clause.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170117/a5393a4a/attachment.html>
