[Qgis-user] PostGIS Topology
Sandro Santilli
strk at kbt.io
Fri Jan 20 02:46:32 PST 2017
Adding some pointers into the documentation, and as I realize
you're on the QGIS users mailing list, I'd suggest to also
consider contributing support for this procedure in the
DBManager (core plugin) or the postgis topology editor plugin
(http://github.com/strk/qgis_pgis_topoedit).
Following, docs pointers
On Fri, Jan 20, 2017 at 11:37:02AM +0100, Sandro Santilli wrote:
> 1. Load the shapefile into a table
http://postgis.net/docs/manual-2.3/using_postgis_dbmanagement.html#shp2pgsql_usage
> 2. Create a topology
http://postgis.net/docs/manual-2.3/CreateTopology.html
> 3. Add a TopoGeometry column to the table
http://postgis.net/docs/manual-2.3/AddTopoGeometryColumn.html
> 4. Update the table setting the new column with toTopoGeom
http://postgis.net/docs/manual-2.3/toTopoGeom.html
--strk;
