[Qgis-user] QGIS 2.18.2 can not see GRASS data / use GRASS algorithms
Robert Nuske rnuske at gwdg.de
Mon Jan 23 03:39:26 PST 2017
Right Micha!
I now remember you posted that hint already last week.
It somehow feels hackish to create a symlink to an old grass version while
using the recommended combination of repositories [1, 2].
Nevertheless, I can confirm the hack works. I used a symlink to the available
generic grass command:  sudo   ln -s  /usr/bin/grass  /usr/bin/grass70
thanks
  robert
[1] http://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
[2] snippet from my sources.list:
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu xenial main
deb http://qgis.org/ubuntugis xenial main
Am Montag, 23. Januar 2017, 13:14:06 CET schrieben Sie:
> Processing Toolbox still looks for GRASS at /usr/bin/grass70.
> The workaround I used is to add a softlink:
> sudo ln -s /usr/bin/grass72/usr/bin/grass70
> It was already pointed [1] out that the correct solution would be for
> Processing to use the generic /usr/bin/grass which will always point to
> the current version.
> [1]http://lists.osgeo.org/pipermail/qgis-user/2017-January/038874.html
> On 2017-01-23 12:40 PM, Robert Nuske wrote:
> > Dear benefactor,
> > thanks a lot to the kind soul who did the packaging for 2.18.3 !
> > I now can see and open my GRASS data again in QGIS.
> > But I still can not execute GRASS commands from the Processing Toolbox.
> > I still get the same error message claiming my GRASS is not installed
> > correctly. But I can open GRASS 7.2 from the command line w/o problems.
> > Is there a setting telling QGIS where to look for GRASS?
> > I didn't find anything in the processing options. The GRASS GIS 7 commands
> > are already activated and the path to the GRASS 7 docs is fine.
> > cheers
> >    robert
> > Am Donnerstag, 12. Januar 2017, 16:25:07 CET schrieb Robert Nuske:
> >> Dear List
> >> I can not see/load my GRASS data from within QGIS anymore and can not use
> >> the GRASS algorithms offered in the Processing Toolbox (GRASS GIS 7
> >> commands are activated in the Processing options).
> >> Trying to run v.info from the Toolbox I get the following error message:
> >> This algorithm cannot be run :-(
> >> It seems that GRASS GIS 7 is not correctly installed and configured in
> >> your
> >> system. Please install it before running GRASS GIS 7 algorithms.
> >> Starting QGIS on the command line does not produce suspicious output:
> >> $ qgis
> >> Warning: loading of qgis translation failed
> >> [/usr/share/qgis/i18n//qgis_en_US] Warning: loading of qt translation
> >> failed [/usr/share/qt4/translations/ qt_en_US]
> >> Warning: QCss::Parser - Failed to load file  "/style.qss"
> >> Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
> >> "mWidgetStack", which already has a layout
> >> QGIS 2.18.2  was installed this week on a new computer running kubuntu
> >> 16.04.1 (xenial) amd64 using the following repositories
> >>    xenial
> >> main deb http://qgis.org/ubuntugis xenial main
> >> Please see below for a list of qgis related installed packages.
> >> Do I use the wrong repositories or does anything else need to be
> >> configured?
> >> Any hints are more than welcome.
> >> Thanks
> >>    Robert
> >> $ dpkg -s qgis
> >> Package: qgis
> >> Status: install ok installed
> >> Priority: optional
> >> Section: science
> >> Installed-Size: 18417
> >> Maintainer: QGIS developers <qgis-developer at lists.osgeo.org>
> >> Architecture: amd64
> >> Version: 1:2.18.2+24xenial-ubuntugis
> >> $ dpkg -s grass
> >> Package: grass
> >> Priority: optional
> >> Section: metapackages
> >> Installed-Size: 35
> >> Maintainer: Debian GIS Project <pkg-grass-devel at lists.alioth.debian.org>
> >> Architecture: all
> >> Version: 7.2.0-1~xenial2
> >> $ aptitude search qgis | grep ^i
> >> i A libqgis-analysis2.18.2          - QGIS - shared analysis library
> >> i A libqgis-app2.18.2               - QGIS - shared app library
> >> i A libqgis-core2.18.2              - QGIS - shared core library
> >> i A libqgis-customwidgets           - QGIS custom widgets for Qt Designer
> >> i A libqgis-gui2.18.2               - QGIS - shared gui library
> >> i A libqgis-networkanalysis2.18.2   - QGIS - shared network analysis
> >> library i A libqgis-server2.18.2            - QGIS - shared server
> >> library i A libqgisgrass7-2.18.2            - QGIS - shared grass
> >> library
> >> i A libqgispython2.18.2             - QGIS - shared Python library
> >> i A python-qgis                     - Python bindings to QGIS
> >> i A python-qgis-common              - Python bindings to QGIS -
> >> architecture i   qgis                            - Geografisches
> >> Informationssystem (GIS) i A qgis-common                     - QGIS -
> >> architecture-independent data i A qgis-plugin-globe               - OSG
> >> globe plugin for QGIS i A qgis-plugin-globe-common        - OSG globe
> >> plugin for QGIS - arch i A qgis-plugin-grass               - GRASS
> >> plugin for QGIS
> >> i A qgis-plugin-grass-common        - GRASS plugin for QGIS -
> >> architecture
> >> i A qgis-provider-grass             - GRASS provider for QGIS
> >> i A qgis-providers                  - collection of data providers to
> >> QGIS
> >> i A qgis-providers-common           - collection of data providers to
> >> QGIS
> >> $ aptitude search grass | grep ^i
> >> i   grass                           - Geographic Resources Analysis
> >> Support
> >> i A grass-core                      - GRASS-GIS-Kernkomponenten
> >> i A grass-doc                       - GRASS GIS user documentation
> >> i A grass-gui                       - GRASS GIS graphical user interfaces
> >> i A libqgisgrass7-2.18.2            - QGIS - shared grass library
> >> i A qgis-plugin-grass               - GRASS plugin for QGIS
> >> architecture-
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
