[Qgis-user] Legend block behaviour in composer
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Jan 27 02:09:44 PST 2017
Nyall,
While the legend is selected go to *Item* *Properties*, *Legend Items*
there is a tick box *Auto Update* untick it.
I think this should do what you want, the problem is though that if you
add other layers and wish to add them, change them, they wont be added
to the legend unless you refresh, which will result in a resetting of
the layers, hope this helps.
Regards
Richard.
On 27/01/2017 00:49, Nyall Dawson wrote:
> On 27 January 2017 at 09:25, Laurence Béchet <bechet.laurence at gmail.com> wrote:
>> Hi,
>> I have several blocks of legend in my composer that I group together to have
>> a final nice display:
>> https://dl.dropboxusercontent.com/u/92195218/legend.jpg
>> To do so I have to stretch each block so that the final version looks like
>> one single block and not several blocks put together:
>> https://dl.dropboxusercontent.com/u/92195218/legendORG.jpg
>> A very annoying thing is that each time I refresh the composer, my legends
>> get refreshed to their original rectangle and I have to reshape everything
>> ... I thought that if I locked the blocks they would not get refreshed - but
>> they do. I also tried to group them, but again they get refreshed. Is there
>> a way to keep the final shape?
> Uncheck "resize to fit contents" under the legend item properties,
> "main properties" section.
>> Also it took me a while to discover that to pick up several blocks one by
>> one you need to use the shift key and not the control key (as in most
>> software). Is it normal or is it something I can configure somewhere?
> Shift is the standard used in layout/illustration packages. Ctrl
> clicking cycles through selecting overlapping elements.
> Nyall
> Qgis-user mailing list
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170127/f019f465/attachment.html>
