[Qgis-user] How can I define the space between lines in a hatched fill pattern?
Raymond Nijssen
r.nijssen at terglobo.nl
Sun Jan 29 03:04:34 PST 2017
Hi Khandoker,
In the "Line pattern fill" dialog in the Style tab, there are options
for distance, rotation and offset for your lines.
You can use millimeters, pixels or map units as units for the distance
value.
Good luck,
Raymond
On 29-01-17 11:58, Khandoker Maniruzzaman wrote:
> I am using hatched fill patterns for some polygons in a map. The hatch
> looks okay in the map composition. But in the exported jpeg file, the
> hatch lines are so close to each other, the fill looks like a shade of
> grey. It is difficult to distinguish the horizontal, vertical and
> diagonal hatches. Is there a way I can control the distance between
> lines in the pattern?
> Thanks in anticipation.
> Khandoker
> Qgis-user mailing list
