[Qgis-user] Spatial Search Of Oracle Table by QGIS
Simon Greener
simon at spatialdbadvisor.com
Sun Jan 29 21:47:40 PST 2017
Background.
I executed an "identify" in QGIS against a single mapped object that comes
from an Oracle table with sdo_geometry column.
I dumped the SQL that QGIS executes and I got the following (which I have
compared to the C++ source code):
SELECT "GEOM","ROWID","FID","FID_INT","FID_NUM9","FID_NUM8","FID_NUM7",
"AN_ATTRIBUTE"
FROM
"QGIS"."FOO" "FEATUREREQUEST"
WHERE sdo_filter("GEOM",
mdsys.sdo_geometry(2003,2872,NULL,mdsys.sdo_elem_info_array(1,1003,3),
mdsys.sdo_ordinate_array(5992381.68001308757811785,
2112468.83721287222579122,5992389.06444318685680628,
2112476.22164297243580222)))='TRUE'
AND sdo_relate("GEOM",
2112476.22164297243580222)),'mask=ANYINTERACT')='TRUE'
My question is this. Why does QGIS execute a primary filter (SDO_FILTER)
followed by a secondary filter (SDO_RELATE)? The reason why I ask is that
the secondary filter SDO_RELATE firstly executes its own primary filter
before processing the candidates for the spatial relationship.
The SDO_FILTER is not needed. The Oracle Query Optimizer is still not smart
enough to realise that the sdo_filter is not needed.
regards
Simon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Spatial-Search-Of-Oracle-Table-by-QGIS-tp5305258.html
Sent from the QGIS - User mailing list archive at Nabble.com.
