[Qgis-user] Detecting Geometry Type For Oracle Object
Jürgen E. Fischer
jef at norbit.de
Tue Jan 31 14:49:34 PST 2017
Hi Simon,
On Sun, 29. Jan 2017 at 22:42:22 -0700, Simon Greener wrote:
> QGIS, when querying Oracle to determine the geometry type in a table's
> sdo_geometry column executes the following SQL:
> SELECT DISTINCT gtype FROM (SELECT t."GEOMETRY".sdo_gtype AS gtype FROM
> "<XXXX>"."<TABLENAME>" t WHERE t."GEOMETRY" IS NOT NULL AND rownum<1000)
> WHERE rownum<=2
> If there any way that I can force QGIS to change the number it samples?
No, that's hardwired - but it's 100 on 2.18 and master.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170131/331429dd/attachment.sig>
