[Qgis-user] limiting contour lines to range of elevations
Matt Boyd mattslists at gmail.com
Mon Jul 3 03:23:26 PDT 2017
Right click on the contour other and filter.
You can select only the contours you want field=X or field=y.
The syntax is in SQL, so you can look up a query that matches your
requirements..
On 1 Jul. 2017 4:00 am, "imagineaerial" <info at imagine-aerial.com> wrote:
> Hey all,
> New QGIS user here and I have been experimenting with a few holes on our
> clients golf courses.  I was wondering how I can display contour lines on
> DSM maps but only display a range of elevations (i.e. from 0 - 10 ft
> elevation).  Most of the courses have tree lined holes and we only need the
> contours to show up on the turf area, not the trees and buildings.
> Thanks all,
> - Mike
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/limiting-contour-lines-to-range-of-elevations-tp5326289.html
> Sent from the QGIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170703/36055b88/attachment.html>
