[Qgis-user] SAGA missing from the processing toolbox?
Laurence Béchet bechet.laurence at gmail.com
Wed Jul 5 14:48:22 PDT 2017
Thanks Micha for the tip. The function didn't look that way a few years
ago and that's why I had given up using the default raster analysis tool.
So I tried to use the gdal_grid function and ... I got an error message:
ERROR 1: Attempt to create ADRG dataset with an illegal data type
(Float64), only Byte supported by the format.
I looked on internet, but didn't find anything useful.
So I'm back to square1 .... and cannot produce the map I need ...
Cheers
Laurence
On 5/07/2017 6:43 p.m., Micha Silver wrote:
> I don't know why you're having trouble with the processing toolbox,
> but regarding IDW interpolation, you can do it straight in the Raster
> menu, *Raster->Analysis->Grid (interpolation)*. This uses the
> gdal_grid utility
> On 07/05/2017 06:35 AM, Laurence Béchet wrote:
>> Hi
>> I need to use the Inverse Distance Weighted Interpolation from SAGA
>> within qGIS, which I did with a previous version of qGIs but this
>> time it didn't work because of a missing library (qGIS 2.18.9 -
>> windows8 pro, 64bits).
>> I updated the qGIS version with the latest 2.18.10 (windows8 pro, 64
>> bits), but this time the SAGA tools are not displayed at all in the
>> list, despite they are ticked in the config file.
>> Is this normal? What is then the workaround for the IDW interpolation?
>> Also the path to grass7 in the config file is wrong (processing /
>> options), which makes it crash ... Is this also normal?
>> Thanks for the help in advance!
>> Laurence Bechet
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170706/5dc59a8b/attachment.html>
