[Qgis-user] Area Calculations - what the h... is going on?
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Sun Jul 9 19:43:33 PDT 2017
Good work
Von einem iPhone gesendet und wird daher Fehler enthalten…
Am 10.07.2017 um 04:00 schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On 7 July 2017 at 00:38, magerlin <MAP at ramboll.dk> wrote:
>> I normally use $area in the field calculator to calculate areas of polygon
>> but now this is really weird.
>> I have 5 polygons in the same shape file and tries to calculate the areas -
>> but two of the polygon get areas of about 100 times as big as they should be
>> while the 3 remaining polygons get ok areas. If I use area($geometry)
>> instead I get OK areas:
> Thanks for reporting this - I've identified the issue and it's fixed
> now in master and the 2.18 branch (so fix will be in 2.18.11)
> Nyall
> Qgis-user mailing list
