[Qgis-user] DXF export.
Siki Zoltan
siki at agt.bme.hu
Wed Jul 12 04:36:07 PDT 2017
Dear Charles,
Rasters cannot be involved in DXF export (as Jürgen wrote).
You had better to use QuickMapServices or Openlayers plug-in, no need to
manual georeferencing. These plug-ins are able to display google, osm, ...
maps from the web.
Best regards,
Zoltan
On Wed, 12 Jul 2017, Charles Barrows wrote:
> I'm rather new to QGIS but very impressed with its capabilities.
> I'm trying to georeference a raster photo from Google Earth. Using the
> GeoReferencer plugin I go through the procedure using data points in a
> decimal degree format. WGS84 survey. The procedure seems to go OK,
> including the "start georeferencer" and the Load to QGIS. I am using the
> Transformational type Polynomial 2. But, the DXF export fails. What am I
> missing?
> I have been entering the longitude into the x/box as a negative number
> because I am in the western hemisphere. Does the program not like negative
> numbers?
> Charley B.
