[Qgis-user] Maximum number of layers
David J. Bakeman
dbakeman at comcast.net
Sun Jul 16 12:11:21 PDT 2017
On 07/15/2017 01:50 PM, Nicolas Cadieux wrote:
> Hi,
> What is the maximum number of layers I can open in Qgis? Is there a setting I can change to increase it?
I don't know about Windows but on Linux it's at least partially a
operating system setting. That is the number of open files.
In my case I wanted to open several thousand shapefiles (each shapefile
is actually 3-4 files).
So in Linux there is a limit/ulimit command you can use to increase the
number of open file descriptors but it can only increase it up to the
hard limit. To increase the hard limit I added a file to the system
directory which sets various limits in /etc/security/limits.d I called
it 99-nofile.con in it I increased the hard limit to 65536. Check
/etc/security/limits.conf for examples. Then I rebooted now I've been
able to work with projects with thousands of shapefiles with no problem.
I have lots of memory(128GB) which might be a factor as well.
> Thanks
> Nicolas
> Qgis-user mailing list
