[Qgis-user] raster calculator issues
frippe12573 frippe12573 at hotmail.com
Fri Jul 21 06:11:37 PDT 2017
hi all,
I'm using qgis 2.18.10 (code59e0f78) installed from repo in my Ubuntu 17.04.
I have problem with raster calculators algorithms. In particular:
saga (2.3.1) raster calculator - it gives me this error, both using this
algorithm in a process and alone:
Error executing algorithm reservoir_effective 'module' object has no
attribute 'TYPE_RASTER' See log for more details
gdal/ogr raster calculator - it gives this error:
GDAL command output:
Error! Dimensions of file /home/condivisa_A_E/calcoli/1000_ET_pos.tif (600,
562) are different from other files (473, 562). Cannot proceed
r.mapcalc - it doesn't show a filed to set the name of the output file, but
only the folder. However it gives this error on the console: ERROR 4:
/home/IGG/condivisa_A_E/calcoli/1000_ET_pos.tif;/home/layer_prodotti_da_caricare/Z90_ly.tif:
No such file or directory
The only algorithm currently running seems to be the raster calculator of
gdal available as first item in the raster menu.
Thank you for any hint you can give me
E.
View this message in context: http://osgeo-org.1560.x6.nabble.com/raster-calculator-issues-tp5328659.html
Sent from the QGIS - User mailing list archive at Nabble.com.
