[Qgis-user] raster calculator issues
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Fri Jul 21 06:30:52 PDT 2017
It was already fixed Eugenio:
https://github.com/qgis/QGIS/commit/74042a2dc061aba0f8c5ecc15efa111153c97bb0
Best regards,
Pedro
2017-07-21 14:11 GMT+01:00 frippe12573 <frippe12573 at hotmail.com>:
> hi all,
> I'm using qgis 2.18.10 (code59e0f78) installed from repo in my Ubuntu
> 17.04.
> I have problem with raster calculators algorithms. In particular:
> saga (2.3.1) raster calculator - it gives me this error, both using this
> algorithm in a process and alone:
> Error executing algorithm reservoir_effective 'module' object has no
> attribute 'TYPE_RASTER' See log for more details
> gdal/ogr raster calculator - it gives this error:
> GDAL command output:
> Error! Dimensions of file /home/condivisa_A_E/calcoli/1000_ET_pos.tif
> (600,
> 562) are different from other files (473, 562). Cannot proceed
> r.mapcalc - it doesn't show a filed to set the name of the output file, but
> only the folder. However it gives this error on the console: ERROR 4:
> /home/IGG/condivisa_A_E/calcoli/1000_ET_pos.tif;/home/
> layer_prodotti_da_caricare/Z90_ly.tif:
> No such file or directory
> The only algorithm currently running seems to be the raster calculator of
> gdal available as first item in the raster menu.
> Thank you for any hint you can give me
> E.
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/raster-calculator-issues-tp5328659.html
> Sent from the QGIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170721/2a441982/attachment.html>
