[Qgis-user] field calculator add field to .csv layer
Janneke van Dijk
janneke.qgis at gmail.com
Sat Jun 3 10:39:57 PDT 2017
Thanks, Stéphane.
That at least confirms it - the capabilities are then a bit misleading,
if the layer is not meant to be editable.
regards,
Janneke
On 31-May-17 12:31, Stéphane Henriod wrote:
> Hi Janneke
> If I'm not mistaking, the csv files are read-only in Qgis. So I guess
> it's not a bug
> I just tested here and all I can do is to add a virtual field to the
> csv, but not actually write in the file.
> Cheers
> Stéphane
> Le lundi 29 mai 2017, Janneke van Dijk <janneke.qgis at gmail.com
> <mailto:janneke.qgis at gmail.com>> a écrit :
> Dear all,
> Using Qgis 2.18.9 on Windows (OSGeo4W64) I'm trying to import a
> .csv file and adding a text field. This is what I do:
> 1. add the .csv using add vector layer
> 2. open attribute table then use the field calculator
> 3. add text field, OK
> 4. toggle editing, save edits when asked.
> I then get the following error messages:
> Could not commit changes to layer test_fieldcalculator1
> Errors: ERROR: 1 new attribute(s) not added
> SUCCESS: 1 attribute value(s) changed.
> Provider errors:
> OGR error creating field txt:
> Feature 1 for attribute update not found.
> OGR error syncing to disk:
> The capabilities of this layer show:
> Add Features, Delete Features, Change Attribute Values, Add
> Attributes, Delete Attributes, Rename Attributes, Change
> Geometries, Curved Geometries
> which makes me think it should be possible to add attributes to
> this layer. Is this a bug or am I missing something? If a bug, is
> it in OGR or QGIS?
> Thanks for any insight,
> Janneke
> Stéphane Henriod
> CIM-Expert for GIS and Green Economy Statistics
> Национальный статистический комитет Кыргызской Республики
> Кыргыз Республикасынын Улуттук статистика комитети
> National Statistical Committee of the Kyrgyz Republic
> 374 Фрунзе ул. / Frunze str.
> 720033 Бишкек / Bishkek
> T +996 778 46 99 02 (KG)
> T +49 176 280 11 050 (DE)
> E s at henriod.info <mailto:s at henriod.info>
> W http://www.stat.kg
> W3W: nightfall.into.bucket
> <https://map.what3words.com/nightfall.into.bucket> //
> запас.союз.дружный
> <https://map.what3words.com/%D0%B7%D0%B0%D0%BF%D0%B0%D1%81.%D1%81%D0%BE%D1%8E%D0%B7.%D0%B4%D1%80%D1%83%D0%B6%D0%BD%D1%8B%D0%B9>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170603/ad15dce0/attachment.html>
