[Qgis-user] Ubuntu 16.04 dependency problem (qgis-2.18.9 and	python-sip)
    Slawomir Bienias
    slawomir.bienias at gmail.com
    Tue Jun  6 13:33:05 PDT 2017
Andre Joost wrote
> Am 06.06.2017 um 11:06 schrieb SaekBinko:
>> Hello,
>> I updated my OS, and my system now has dependency problem. I think the
>> problem is with python-sip package. python-sip was updated (to python-sip
>> (4.19.2+dfsg-1+16.04+xenial+build3) and python3-sip
>> (4.19.2+dfsg-1+16.04+xenial+build3)), and QGIS (2.18.9) has been removed
>> automatically...
>> When I want to install qgis terminal shows me, that I need to install
>> python-qgis. So, when I want to install python-qgis, terminal tells me,
>> that
>> I need to install python-qscintilla2 and sip-api-11.2. And this is the
>> end
>> of my journey, because sip-api is virtual package of python-sip, which
>> has
>> been updated.
> I wonder where you got that python-sip from. The main ubuntu repo has
> 4.17, and that works with the latest QGIS builds for me.
> Try apt-cache policy python-sip to see which versions are available for
> you. I see version 4.19.2 only in Debian experimental.
> HTH,
> André Joost
> Qgis-user mailing list
> Qgis-user at .osgeo
Thank You, I forgot to check apt-cache.
You were right - 4.19.2 is from KDE Neon repo in my OS.
QGIS installed and it works fine now.
Thanks a lot!
Best regards,
Sławomir Bienias
View this message in context: http://osgeo-org.1560.x6.nabble.com/Ubuntu-16-04-dependency-problem-qgis-2-18-9-and-python-sip-tp5323162p5323265.html
Sent from the QGIS - User mailing list archive at Nabble.com.
