[Qgis-user] Confirming Problem Importing Geopackage Data?
Even Rouault
even.rouault at spatialys.com
Wed Jun 7 04:15:22 PDT 2017
On mercredi 7 juin 2017 13:09:53 CEST Tobias Wendorff wrote:
> Am Di, 6.06.2017, 22:11 schrieb Even Rouault:
> > Renaming the layers in ArcMap probably fixed the case inconsistency.
> > Fixed per https://trac.osgeo.org/gdal/ticket/6916
> I don't know, if .gpkg allows UTF8 characters in column name.
> Doesn't lower() introduce problems with UTF8? Some characters might
> turn into a different notation? Don't know exactly, just want to
> give a hint ;)
Indee from https://sqlite.org/lang_corefunc.html#lower ,
"The lower(X) function returns a copy of string X with all ASCII characters converted to lower
case. The default built-in lower() function works for ASCII characters only."
it is not very clear what happens when non ASCII characters are encountered.
Little experiment :
$ sqlite3
sqlite> select lower('EéE');
eée
So apparently it lets non-ASCII UTF-8 characters unchanged, so I think using lower() should be
safe
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170607/8496dcca/attachment.html>
