[Qgis-user] problems with 'geometry creator'
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Sun Jun 11 09:03:06 PDT 2017
Dear *Matthias*!
Am So, 11.06.2017, 12:25 schrieb Matthias Kuhn:
[switching order of the original mail]
> It also helps a lot to answer with the correct name of the person who
> responded. While this technically doesn't solve any current issues, it
> considerably improves the chances of receiving answers to future
> questions ;)
I really have to apologize for naming you "Martin" and not following
your recommendation. Actually, I was in a hurry and wanted to answer
the mail before being unavailable for some hours (until now).
> Most often it actually helps a lot if you follow the advice you
> receive. Sometimes - if you are lucky - they even produce better
> results for you than trying random things.
Actually, I'm not trying to do random things. Have a look at this:
https://github.com/qgis/QGIS/blob/master/resources/function_help/json/line_merge
As you can see, the function should return "a LineString or
MultiLineString geometry, where any connected LineStrings from
the input geometry have been merged into a single linestring."
The example also shoes input being "MULTILINESTRING". So my testcase
wasn't as random as you might expect.
Best regards,
Tobias
