[Qgis-user] [processing] gdal warp -te confusion
Andreas Plesch
andreasplesch at netscape.net
Sun Jun 11 15:40:35 PDT 2017
I am using the gdal warp (reproject) processing algorithm in 2.18.9 with
the 'Set georeferenced extents of output file' option, eg. the -te command
line switch.
I am warping from unprojected to UTM coordinates.
Here is a correctly constructed console call
gdalwarp -ot Float32 -t_srs EPSG:32611 -r near -of GTiff -te 222749.290374
3763741.53271 317609.171896 3877346.18124 -co COMPRESS=DEFLATE -co
PREDICTOR=1 -co ZLEVEL=6 -wo OPTIMIZE_SIZE=TRUE
C:\Users\andreas\Documents\x3d\n35w120\grdn35w120_clipped_600x700.tif
"[temporary file]"
(Sometimes the shown console command does not seem to get updated properly,
but the executed command seems to be always correct)
When I now 'Run' the algo, there is this warning:
'Extent parameters must use the same CRS as the input layers.
Your input layers do not have the same extent as the project, so the extent
might be in a wrong CRS if you have selected it from the canvas.'
The project crs is the warp destination crs (UTM).
The warning is misleading since gdalwarp by default will use the _target_
crs:
*-te* *xmin ymin xmax ymax*:set georeferenced extents of output file to be
created (in target SRS by default, or in the SRS specified with -te_srs)
Furthermore, the extent parameters can be in any srs if the -te_srs option
is used.
So to me the warning is quite irritating.
Additionally, I am using the algorithm in a model where I know the inputs
for the extents are correct. Is there a way to silence these wanrings in
models ?
THanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170611/208d5f03/attachment.html>
