[Qgis-user] Split features tool behavior
Andreas Wicht
a.wicht at gmail.com
Mon Jun 19 01:05:15 PDT 2017
Hi Bernhard,
I can consistently produce a python error when splitting a Multipart
Feature and then clicking "No to all":
UnboundLocalError: local variable 'newGeoms' referenced before assignment
File "C:\Users\Andreas.Wicht\.qgis2\python\plugins\DigitizingTools\tools\dtsplitfeature.py",
line 139, in digitizingFinished
newFeatures = dtutils.dtMakeFeaturesFromGeometries(self.editLayer,
aFeat, newGeoms)
Python version: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64
bit (AMD64)]
QGIS version: 2.18.9 Las Palmas, 3a16a4e
Is that case maybe not covered properly or should I search for causes on my end?
On 19 June 2017 at 08:28, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
> Hi Andreas,
> the color is currently defined in the code. I did not find any setting to
> apply. AFAIK only selection color can be defined by the user, but it might
> be misleading if you have a selected feature and then have split parts
> colored exactly the same. - Wait a minute I just found the "Highlight
> color". That would probably work. Will check.
Okay. Thank you!
> Am 17.06.2017 um 13:22 schrieb Andreas Wicht:
>> Hi Bernhard,
>> just got to test the new version. It works now as expected.
>> Thank you a lot for the good work there!
>> Is the highlight color of the currently "selected" part (when you
>> choose which part should form the new feature) defined in the code or
>> does it use a color, which is set in the QGIS settings?
