[Qgis-user] Split features tool behavior
Andreas Wicht a.wicht at gmail.com
Tue Jun 20 00:24:17 PDT 2017
Hi Bernhard,
perfect! Both works for me.
A nice-to-have for the future would also be the utilization of the
tracing function in case tracing is enabled.
I can not assess how much work that would mean.
cheers
On 19 June 2017 at 18:05, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
> Hi Andreas,
> has been fixed; split feature now uses the highlight color, too
> Please update your plugin
> Bernhard
> Am 19.06.2017 um 10:05 schrieb Andreas Wicht:
>> Hi Bernhard,
>> I can consistently  produce a python error when splitting a Multipart
>> Feature and then clicking "No to all":
>> UnboundLocalError: local variable 'newGeoms' referenced before assignment
>> Traceback (most recent call last):
>>   File
>> "C:\Users\Andreas.Wicht\.qgis2\python\plugins\DigitizingTools\tools\dtsplitfeature.py",
>> line 139, in digitizingFinished
>>     newFeatures = dtutils.dtMakeFeaturesFromGeometries(self.editLayer,
>>  aFeat,  newGeoms)
>> Python version: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64
>> bit (AMD64)]
>> QGIS version: 2.18.9 Las Palmas, 3a16a4e
>> Is that case maybe not covered properly or should I search for causes on
>> my end?
>> On 19 June 2017 at 08:28, Bernhard Ströbl <bernhard.stroebl at jena.de>
>> wrote:
>>> Hi Andreas,
>>> the color is currently defined in the code. I did not find any setting to
>>> apply. AFAIK only selection color can be defined by the user, but it
>>> might
>>> be misleading if you have a selected feature and then have split parts
>>> colored exactly the same. - Wait a minute I just found the "Highlight
>>> color". That would probably work. Will check.
>> Okay. Thank you!
>>> Am 17.06.2017 um 13:22 schrieb Andreas Wicht:
>>>> Hi Bernhard,
>>>> just got to test the new version. It works now as expected.
>>>> Thank you a lot for the good work there!
>>>> Is the highlight color of the currently "selected" part (when you
>>>> choose which part should form the new feature) defined in the code or
>>>> does it use a color, which is set in the QGIS settings?
